Door Tops (and panels) supposed to be loose?
Subscribe
May 31, 2011 | 05:20 AM
I'm putting the interior into my 87 Trans AM project car that I bought (without any door panels).
I reattached the door panel to the the panel top (black plastic piece that sits on top of the door panel). I pushed the grey metal clips on the back of the panel and pushed them down with a set of needle nose pliers.
The top and bottom of the door panel seems to be lose though. That is to say it looks like the grey metal clips don't seem to be tight. Is it supposed to be this way or is the door panel and top supposed to be a tight fit?
How can I fix this?
Reply 0
May 31, 2011 | 09:27 AM
Re: Door Tops (and panels) supposed to be loose?
Our panels unfortunately become very filmsy over time (I'm not sure if they were ever solid even from the factory).
For the plastic top peice and the panel: I added attachment points on the outermost part to attach it even more because it kind of wobbled and I didn't like the fact that over bumps I could hear the door panel jumping up with the car lol. I recall I used nuts and bolts to attach it.. Probably a bit overkill but it did the job and made it much more solid. You have to be careful not to use ones that are too big or ones that will obstruct the window from moving in there otherwise you might scratch your window! Mine comes very close but far enough to be safe and not scratch. Try to use bolts that stick out the least.
I also glued it with crazy glue so it wouldn't come off or wiggle.. It just makes for a more solid contact from the top panel to the "flimsy" door panel.
As for the plastic clips that go around the bottom and side edges of the panel, I have never seen those metal clips before?! That's a good idea because mine is torn up in the paper backing that the clips attach to. Nevertheless, my door is solid where those plastic clips connect to the metal door frame. Not sure if that's the part that was loose?
EDIT: While you're in the door you could do alot to help in there.. Adjust windows, replace fuzzies, tighten up everything, grease everything with white lithium grease, zip tie things that rattle, add insulation to metal that rattles alongside other metal peices such as rod linkages, etc. This all made my door as quiet as a new car. Also replacing door bushings that are worn out helps tremendously! JAMES C did a great writeup of gettin the doors silent you should definitely read that it's what gave me alot of ideas. Good luck!
Reply 0
May 31, 2011 | 12:14 PM
My door panel is pretty solid. It's just where the door panel attaches to the (Black) top panel that is flimsy. I'm afraid that the metal cips that attach the two pieces are going to fall out with the door opening and closing all the time and then the top black panel will pop off from the door panel.
Might try crazy glue or gorrilla glue to stick everything together.
FYI...the door panel came with the metal clips (I presume they are factory). I just added some new white plastic clips.
Reply 0
May 31, 2011 | 02:30 PM
The gta deluxe door panels came with those metal clips.
Reply 0
Subscribe
