Fatmat on door panels?
Old Jun 4, 2011 | 10:36 AM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Axle/Gears: 3:27 BW 9 bolt
I cant decide if I should put my Fatmat on the door itself, or on the back of the door panels. I'm hoping to quiet down some of the squeaks and rattles in the door, as well as reduce road noise. Has anyone here put the mat on the door panels instead of the door? Does it cause any issues getting the panel back on?
Old Jun 4, 2011 | 11:21 AM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: Fatmat on door panels?
You can put it on the door panels without any issues (brackets stick out like 3/8" or so), but it's not going to quiet anything down with the gaps around the window glass. Best bet would be to put some sort of cushioning around the rods and what not as they run around the door shell.
Old Jun 4, 2011 | 11:30 AM
el_muerte's Avatar
Car: '87 Z-28
Engine: LT1-topped 400
If you've taken the door panels off, check for junk inside the door rattling around... both of my doors had large chunks of some hardened red goo that was making a ton of noise rattling around.
Old Jun 4, 2011 | 11:43 AM
Engine: 2.7L V6
Axle/Gears: 4.41
Those chunks would be factory body seam sealer broken off... Might want to find out where they came from.
Old Jun 4, 2011 | 09:30 PM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
I've already cleaned mine out, it was just some old leaves. So it's a waste of time putting Fatmat in the doors?
Old Jun 5, 2011 | 11:51 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
I used SmittyMats.com
find em on ebay too but their online store is cheaper
and put it on the back side of the door pannel.
the hosed down insides of the door with rattle can truck bed liner.
Water will get into doors sooner or later.
better protection with the liner and stop the tin sound of the outter skin.
Old Jun 5, 2011 | 11:57 AM
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
I have used several, but Dynamat performs the best for me. Line the inside of the outer skin and the outside of the inner skin. Use Vacuum tube on all the door rods and double up on the Dynamat at the contact points where the rods hit the door skin, PARTICULARLY the lock rod.
Remove and thoroughly clean and lube the latch mechanism, door handle and lock. That will help a LOT too...
I am writing a how-to on the door handle to post soon...
Hotrodboba400
Dec 10, 2019 07:07 PM
RyanJB
May 7, 2016 06:23 PM
tglennon11
Sep 23, 2015 05:30 PM
NiG
Sep 7, 2015 11:25 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
