Rear Seatbelt removal
Old Jun 6, 2011 | 08:48 AM
rdhanded2's Avatar
Top Answer: 1
Car: 91 TA / 91 Formula
Other than the nut, what is holding them in? I have it removed and they are loose but won't come out and I can not see anything else holding them in.
Old Jun 6, 2011 | 08:57 AM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Re: Rear Seatbelt removal
nut? there should only be a long torx screw holding them in
Old Jun 6, 2011 | 09:10 AM
rdhanded2's Avatar
Top Answer: 1
On the rear belts? The front have a 47torx but the rears have a nut.
Old Jun 6, 2011 | 09:30 AM
G-reg's Avatar
Car: 90 Camaro
Engine: 350 tpi
Transmission: t56
Axle/Gears: 4.10
Once you have the nut off I think you have to rotate or slide the whole assembly to the side a little bit, there's a tab in a slot that holds it in place.
Old Jun 6, 2011 | 10:05 AM
rdhanded2's Avatar
Top Answer: 1
Awesome, thanks. I will give that a try
Old Jun 6, 2011 | 12:45 PM
rdhanded2's Avatar
Top Answer: 1
That worked like a charm. Some of the padding had gotten down in there and was keeping them from turning.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
I'llrocya
Feb 2, 2016 11:43 PM
3rdgenparts
Aug 8, 2015 07:09 PM
z28addict8490
Aug 7, 2015 08:48 PM
