Trans Am center console
Old Jul 17, 2011 | 11:01 PM
banksGTA's Avatar
Car: 87 GTA
Axle/Gears: 3.42 posi
My console is seprating along the top and i was wondering if there is a fix for this or do i have to buy another one? Any help would be great.
U.S. NAVY
GODSPEED
Old Jul 18, 2011 | 04:15 AM
MAC_87's Avatar
Car: 1987 IROC-Z
Engine: 5.7L
Re: Trans Am center console
have pics?, best thing I can think of is metal braces and a couple nuts and bolts to hold it together if it's splitting in half (temporarily of course) until a possible replacement...
Old Jul 18, 2011 | 07:29 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
some people have had good luck using an epoxy or gorilla glue and clamping the pad down to get it looking good again. i used it as an excuse to grab a 4th gen console, a cup holder was too appealing!
Old Jul 18, 2011 | 10:14 AM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Axle/Gears: 3:27 BW 9 bolt
TA consoles don't split in half, it's the foam padded outer plastic/vinyl that starts pulling loose from the frame.
Banks, get yourself a small piece of wood, some clamps, a razor knife, and gorilla glue. Remove the shifter plate. You'll need to trim out a little bit of the foam since the glue expands as it dries. Dampen the foam with a spray bottle, then apply the glue (don't use too much or it'll show from the top after it expands). Use the wood and clamps to secure it back together until it dries. You may even wish to use a folded rag or something under the wood to prevent any dimples.
Old Jul 18, 2011 | 10:55 AM
Sparkko's Avatar
Car: 1988 Firebird Formula
Engine: 5.0L 305 TBI
I have the same problem... :P
Old Jul 18, 2011 | 07:58 PM
MNformula350's Avatar
I used some large adjustable wood clamps, 2x4's and Emblem Adhesive to fix my Original Console, when I still had it.
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
DonW
Aug 24, 2015 08:24 PM
Firebird sweden
Aug 16, 2015 05:02 PM
TheJoeY88
Aug 13, 2015 06:51 PM
