Need help with 4th gen set belts
Old Jul 20, 2011 | 06:54 AM
splitface454's Avatar
Car: 92 Camaro RS
Engine: Carb'd 355
Transmission: 5 speed
Axle/Gears: 3:42 gears
Hi all, been a member since 04 and have always found what I was looking for, so I really never needed to post. I bought some 4th gen seats and belts and cannot get the front belts installed. I've read the tech article, searched far and wide and still am lost on how these front belts fit.
Old Jul 20, 2011 | 03:11 PM
Sparkko's Avatar
Car: 1988 Firebird Formula
Engine: 5.0L 305 TBI
Re: Need help with 4th gen set belts
The actual mechanism just bolts right in, with two bolts?
Are you talking about the bottom holder?
Old Jul 20, 2011 | 03:27 PM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
You shouldn't be having any problems installing them.
Old Jul 20, 2011 | 03:39 PM
Car: 92 Camaro RS
Engine: Carb'd 355
Yeah the mechanism that bolts to the floor...there is only one bolt hole in the floor, two holes in the unit. I don't see any way that it fits and it dont sit flush to bolt it down. The belts are out of a 95 if that helps. I think i'm gonna take pics maybe that will help.
Old Jul 20, 2011 | 03:59 PM
Car: 92 Camaro RS
Engine: Carb'd 355
[IMG] Uploaded with ImageShack.us[/IMG]
Ok this is the way "I think" they go in but there is no way it works. The holes don't line up in any way and the bolt is too big to go thru so it would have to be drilled out. Are these even 4th gen belts? They came with my seats which i got from someone on here. I'm lost! lol
Old Jul 20, 2011 | 04:28 PM
The_Wraith's Avatar
Car: 1984 Trans Am 15th anniversary
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
The top portion will bolt up. The one near the floor will leave a big hole where the 3rdgen ones bolted. Since it does not have that big plastic housing to cover it. These belts are simply not worth putting in unless you can find 1982 rocker sills.
The_Wraith's Avatar
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
4thgen belts are a bolt in from that mechanism. I had them in my 86 for a short while. You shouldn't have to drill anything.
Old Jul 20, 2011 | 06:04 PM
GerryCat09's Avatar
Car: 1986 Trans Am WS6/1991 Firebird
Engine: 305 TPI/305 TBI
Transmission: 700R4 in both
Is that a lower retractor? I have a set of belts out of a 2002 Trans Am, and there is no retractor on the floor, just a sheeth with the belt around a plate that bolts to the floor. As far as I've ever seen the 4th gen belts didn't have a lower retractor...what I'm getting at is are you sure those are 4th gen belts, and are you sure that you arn't trying to bolt the upper mechanism to the floor?
Old Jul 20, 2011 | 07:05 PM
Car: 92 Camaro RS
Engine: Carb'd 355
Yeah i'm aware of that I plan to fabricate something to solve that.
Wow you are right! I've had my interior out since 2008 and I feel dumb now LOL Completely forgot how they go back in since I don't have my old belts anymore. Pretty bad when I've taken every single part of my car apart and redone it and get stuck on the seat belts!!! I think I will start a build thread soon so keep an eye out for my name
Thanks to everyone who chimed in for the help in my thread of stupidity!!
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Casey Meyers
Mar 2, 2016 10:46 AM
Navy8125
Aug 22, 2015 07:13 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
