Brooken Speedo-wait that sounded really bad
Old Jul 13, 2011 | 12:26 AM
tylerc's Avatar
I have an 86 Camaro Berlinetta, has the funky kph/mph dual needle gauge in it. I took the car for its maiden voyage the other day on the interstate. Speedometer was off which I expected due to big tires but it just kept climbing until it went around the gauge to about 35 at 60mph. Now when the cars off it stays at about 55mph. Is this likely the gauge being broken? If so I wouldn't remind replacing it, what would swap in directly? What could other issues be? I had to swap the 700r tail-shaft onto the turbo 350 tranny when we put the v8 in with speedometer gears etc... if that may have anything to do with the issue
Please help, thanks!
Old Jul 13, 2011 | 06:48 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Brooken Speedo-wait that sounded really bad
The following link has info on why mechanical speedos fail:
https://www.thirdgen.org/forums/inte...eedo-woes.html
If the speedo head is shot, you can replace it with any mechanical speedo head, 82-89, which includes 85, 110 and 140 (replace only the head or you may experience some electrical gremlins). I'm unsure what the tail shaft replacement might or might not do. The drive and/or driven gears, however, must be appropriate to the rear end gear ratio or the speedo won't read correctly.
JamesC
Old Jul 13, 2011 | 06:44 PM
tylerc's Avatar
If the speed is off a bit due to tire/gear size im okay with that but it sticking like it is isn't acceptable. Sounds like I need to lube up the cable as a first step. Will T/A and Firebird speedometers go in just as easily?
Old Jul 14, 2011 | 08:47 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
A dual-needle speedo in 86? What happened to the digital dash?
Lubing the cable won't have any effect. If you replace the head, Firebird speedometers won't fit. It'll have to be from a Camaro.
Old Jul 14, 2011 | 03:24 PM
tylerc's Avatar
Digital dash would be kinda cool, but it was long gone by the time I got the car.
Old Jul 18, 2011 | 05:40 PM
tylerc's Avatar
What does it take to put a 91/92 speedometer on it? Found a whole cluster for really cheap.
Old Jul 19, 2011 | 09:23 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
A 91/92 interior, plus a bunch of rewiring.
Old Jul 19, 2011 | 11:16 AM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
thier are always clusters for sale on here cheap. check the classified section. Put a want ad out. you'll be able to find what you need.
Old Jul 20, 2011 | 08:36 PM
Mooses92's Avatar
Car: 92 RS Convertible
Engine: 305 ( L03 )
If you cant use it I certainly can! let me know please
Old Jul 20, 2011 | 09:33 PM
tylerc's Avatar
Its on ebay, so feel free :^) I am having a hard time finding it again but I thought it was like 20 bucks for a whole cluster...
Old Jul 20, 2011 | 10:12 PM
Mooses92's Avatar
Engine: 305 ( L03 )
I found this one and put in a bid. for $30 its worth a try
http://cgi.ebay.com/ebaymotors/90-92...#ht_500wt_1182
Old Jul 21, 2011 | 06:52 AM
JamesC's Avatar
Remember that 82-89 and 90+ clusters aren't interchangeable without considerable modification: The first has a mechanical speedo, the second electric. Furthermore, the shape of the two clusters is significantly different.
JamesC
Old Jul 21, 2011 | 06:58 AM
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
I have a 140 MPH cluster from a '88 sitting around that i'd be willing to part with. I don't know if the VSS buffer works but every thing else does.
xxx3man`
Sep 23, 2015 10:37 PM
TheTraut88
Sep 11, 2015 05:16 AM
Amillionoh7
Sep 5, 2015 11:44 PM
greenyone
Sep 2, 2015 03:39 PM
RyanJB
Sep 2, 2015 01:27 PM
