Headlight housing help
Old Jul 24, 2011 | 12:09 AM
iFrye38's Avatar
Car: 1979 Camaro
Engine: 305 5.0 Tpi
So i just got some new headlights and installed them and everything but when i drove at night the lights shot straight out and not on th road. Yes I do know what this is, i simply have to adjust them but the reason they wont go down is cuz i didnt put the spring on. I know you simply take some needle nose and pull the sprin out and attach it to the bezel butttt its not as easy when trying no to mess up the paint. this was done on purpose due to the fact of fresh paint i didnt want to scratch messing around w/ the spring that is a pain
So my question.... is there an easier way to attach the spring or what have you done to fix this?
thanks
Old Jul 24, 2011 | 02:39 AM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Re: Headlight housing help
I had difficulties with the spring myself and just left it disconnected, but it sounds to me like your headlights might be installed upside down. I have no problems with mine not hitting the road and they aren't even adjusted yet, hell my one pair doesn't even have adjustment screws on the sides(haven't gotten to replacing them yet).
Old Jul 24, 2011 | 02:52 PM
iFrye38's Avatar
Car: 1979 Camaro
Engine: 305 5.0 Tpi
there not upside down, they say top on the light itself.. they just point straight out and can see some of the ground just no a lot.
Old Jul 24, 2011 | 04:22 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
those springs work in conjuction with the adjusment screws to keep the light from moving. without the springs, the light is free to move around. are you able to adjust them so they do point were they need to be without the springs?
Old Jul 25, 2011 | 01:20 AM
iFrye38's Avatar
Car: 1979 Camaro
Engine: 305 5.0 Tpi
somewhat yea, im gonna just end up puttin the springs in even if i end up having to touch up the paint in the end....
jrdturbo
Mar 31, 2016 02:58 PM
Briandrex
Oct 5, 2015 06:20 AM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
Eric-86sc
Sep 28, 2015 11:37 AM
6998poncho
Sep 25, 2015 02:56 PM
