Seat Skin Removal? Spilled a large Coke on it...
Old Aug 22, 2011 | 02:18 PM
Motown's Avatar
Car: 1985 IROC-Z
Engine: LB9
Transmission: MD8
Decided to spill my 32oz Coke from the drive thru all over my passenger seat bottom today.
Is there any way to remove the seat skin to wash it? Do they unzip and slide off? Id like to avoid removing the whole seat from the car if possible.
My seats look like this, if it makes a difference.
Old Aug 22, 2011 | 03:00 PM
G-reg's Avatar
Car: 90 Camaro
Engine: 350 tpi
Transmission: t56
Axle/Gears: 4.10
Re: Seat Skin Removal? Spilled a large Coke on it...
Its removable, but not easily. You have to remove the seat from the car, then remove the hinges holding the seat back to the bottom. After that is off, you have to cut the hog rings holding the cover in place, then you'll be able to roll it up the sides of the bottom. Cut a few more hog rings holding the metal rods to the seat foam/center of seat and you can take it off.
You'll need new hog rings and a hog ring pliers to put it back together.
Old Aug 22, 2011 | 03:19 PM
Motown's Avatar
Car: 1985 IROC-Z
Engine: LB9
Transmission: MD8
Didnt know it was that involved.
This goes without saying, Ill use some seat cleaner in a can and some elbow grease.
Thanks for the help.
Old Aug 22, 2011 | 08:10 PM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Axle/Gears: 3:27 BW 9 bolt
Go get yourself a Little Green Clean Machine at WalMart, they're worth the money. You can use it on the seats, carpet, or whatever.
Old Aug 26, 2011 | 12:07 AM
kmcn47's Avatar
Car: 84 Trans Am, 84 Fiero, 86 944
Engine: 5.0, 2.5, 2.5
Transmission: 5spd
wow nice seats, almost the same ones i have in my bird, except mine are charcoal/grey and of course have "the tear"
Old Aug 29, 2011 | 08:51 PM
Stevolwevol's Avatar
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
I have had good results using "Tuff Stuff", a sponge, and a shop vac. No need to remove the seat cover, or anything else.
Old Aug 29, 2011 | 09:03 PM
Motown's Avatar
Car: 1985 IROC-Z
Engine: LB9
Transmission: MD8
I guess I can update...
I bought a foam upholstery cleaner in a blue can and went to town.
The roll of shop towels afterwords look they got done with a bad case of diarrhea duty.
Seat is clean as can be now.
kmcn47, what do you mean by "the tear"? Is there a famous spot for these to rip? Hell mine arent even worn anywhere to give me any hints...
Old Aug 29, 2011 | 09:08 PM
That's why I use a sponge on upolstery.
Old Aug 29, 2011 | 09:13 PM
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
it's amazing what a rug doctor with an uphoulstry tool can do for seats. You will get dirt out that you didn't even know was there
Old Aug 30, 2011 | 12:13 AM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
That's basically what the Little Green does. I can use it on seats that look clean, and still get brown nasty water in the tank.
Old Aug 30, 2011 | 12:32 AM
SKELITOR117's Avatar
Car: 1992 Camaro RS
Engine: 5.0 TBI L03 V8
Transmission: Rebuilt 700R4 W/ Corvette shift kit
Axle/Gears: 2:73 open
That is what I used to clean my seats. Man did it do a stellar job. Just fill it up with hot water. Helps it to evaporate. Even on clean seats you get this sick looking black/brown/yellowish stiff when it sucks the water back up.
Attached Thumbnails Seat Skin Removal? Spilled a large Coke on it...-0830110024.jpg   Seat Skin Removal? Spilled a large Coke on it...-0830110024a.jpg
Old Aug 31, 2011 | 09:10 PM
I used rug shampoo to clean seats with, and had good results. It is very strong stuff, and it seemed hard on the fabric (and my hands). I'd use with caution.
It worked very well on dirty seatbelts that now look tan again.
Old Aug 31, 2011 | 09:13 PM
Car: 1992 Camaro RS
The little green cleans below the surfice. A deeper clean.
Old Aug 31, 2011 | 09:27 PM
58mark's Avatar
man, I've used the green machine... I thought it was pretty wimpy next to a rug doctor or even the steam vac attachments I have hear at the house
this is mine, it does an amazing job
http://www.amazon.com/Hoover-SteamVa.../dp/B00009R66F
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
BlackTopKing
Aug 19, 2015 12:13 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
3rdgenparts
Aug 8, 2015 07:09 PM
