4th gen dash swap ?
Old Sep 19, 2011 | 07:03 PM
GCM-Daniel's Avatar
Car: 92 Camaro RS
Engine: 350 :)
Transmission: 5 Speed
Axle/Gears: 3.73 posi 10 bolt
4th gen dash swap ?
sup guys. i just swapped a 99 camaro dash into my 88 camaro. the guages, ive read that a 93-97 firebird guages will work. im assuming its not a direct plug in. the speedo on mine is cable driven. ive searched and searched but i cant find a answer i need to know asap if possible
Old Sep 27, 2011 | 09:45 AM
GCM-Daniel's Avatar
Car: 92 Camaro RS
Engine: 350 :)
Re: 4th gen dash swap ?
ttt
Old Sep 27, 2011 | 10:33 AM
dellman83Z's Avatar
Car: 87 monte aerocoupe
Engine: 383 HSR w/ novi 2000
Transmission: Built 4l80e circle d converter
Axle/Gears: Currie 9" 3.89 gears
The 93-97 cluster will go right in, but I am not sure about the wiring though. In the electronics section I believe, there are good wiring diagrams. Bascially, I would compare the 93-98 to the 99 and newer ones. As far as the speedo, you will need to either convert the mech speedo on the trans to a elec unit from a 89+ camaro or 88+firebird (not sure about the years, but close) or get a signal converter and dakota digital box (what I did) to convert the cable to a elec signal to make the speedo work. Its a little more money, but more versatile for gear or tire size changes.
Old Oct 4, 2011 | 09:41 AM
GCM-Daniel's Avatar
Car: 92 Camaro RS
Engine: 350 :)
thanks dellman
Jorlain
Aug 24, 2022 05:11 PM
Casey Meyers
Mar 2, 2016 10:46 AM
transam84
Exterior Parts for Sale
Aug 14, 2015 08:54 PM
sreZ28
Aug 14, 2015 07:48 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
