remove dash on a 1986 camaro
Old Sep 20, 2011 | 09:05 PM
xplore's Avatar
Does anyone know where the bolts are and how many there are to remove the dashboard? Maybe a step by step process? The only reason is to pull the rest of the wireing harness.
Old Sep 21, 2011 | 09:06 AM
majobis's Avatar
Car: 1987 IROC Z w/T-Tops
Transmission: Automatic
Axle/Gears: G92
Re: remove dash on a 1986 camaro
Welcome to the site!
If you use the search engine at the middle/top of the page you can find a wealth of information.
6 bolts and 4 screws hold it in place. 4 screws are in the defogger opening areas and the six bolts are under the lip that hangs over the dash area. Be careful when removing it; the vinyl can crack easily and these things aren't cheap!
Old Sep 24, 2011 | 09:16 AM
gotabekidding's Avatar
Car: 91 & 88 GTA, 89 Formy, 89 bird
Engine: 3 - 350 TPI, 305 TBI
Transmission: All 700R4's
Axle/Gears: unknown
"majobis" is correct on the dash pad,
but do you want to remove the entire dash assembly?
Why do you want to remove the entire wiring harness? just curious.
I can walk you through it, if you want?
It takes patience and some time.
Old Sep 27, 2011 | 09:30 AM
xplore's Avatar
I need it to use on the engine and transmission from the 1986 camaro to put in a 1971 sklark
Old Sep 27, 2011 | 06:05 PM
85z28kid's Avatar
Car: 85 iroc-z28
Engine: 049 headed bbc 4?? C.I.D
Axle/Gears: 3:73 posi
It's not that hard remove the center console first. Then the dash pad. Then go under the dash and remove all the litlle bolts, theres a **** load of bolts 7 mm is what I used. Take them all out then try working the dash off. You might miss a few just work it out and you'll get it just have LOTS of patience. Lower he column to it makes it a lot easier in my opinion. Hope it helps I'm in the process of a 4th gen dash right now as I type and just got the dash out
Old Sep 27, 2011 | 07:39 PM
robguitargod1's Avatar
Car: '91 LS6/T56/9"
Engine: LS6
Axle/Gears: Currie 9"/4.11, detroit truetrac
To remove the dash:
See a screw/bolt, remove it.
Vintageracer
Jan 10, 2020 05:33 PM
Street Lethal
Aug 14, 2015 08:25 PM
stalkier
Aug 13, 2015 12:59 PM
Vintageracer
Aug 11, 2015 08:13 PM
3rdgenparts
Aug 8, 2015 07:09 PM
