Dash Lights Not Working!?
Old Oct 1, 2011 | 02:43 PM
UNLV23's Avatar
Hi guys, need a little bit of help. Recently tried to swap my old bulb in the dash area for new LED bulbs. It seems like they arent getting power though. All my other lights work, signals, check engine... But the ones behand the speedo, gas, and rpms wont (even when i put the old bulbs in). Any advice? ohh btw 91 RS 3.1 and i believe i got 194 bulbs. Thanks.
Old Oct 1, 2011 | 08:49 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Dash Lights Not Working!?
Did you try twisting the headlight **** all the way one direction or the other?
Old Oct 1, 2011 | 09:39 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
LEDs don't dim like normal bulbs, so just a little toward "dim" and they are off.
Old Oct 1, 2011 | 09:53 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
also double check brake lights, when they go out your dash lights go out also to help clue you in.
Old Oct 1, 2011 | 10:04 PM
FormulaLT's Avatar
Car: 89 Formula
Not to hijack a thread, but I've wondered what the connection is between the brake lights and dash lights. My dash lights come on when the brake lights come on. And the fuse gets super hot. Any idea?
Old Oct 1, 2011 | 10:35 PM
UNLV23's Avatar
turned the ****, checked the fuse and brake lights. everything works except the speedo gas and rpm lights :/
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
marcusaw
Aug 10, 2015 08:13 AM
apie2546
Aug 8, 2015 07:12 AM
