Need help wiring 02 seats into 91 Firebird
Old Oct 3, 2011 | 07:25 PM
Net-Viper X's Avatar
Car: 91 Bird w/Aero Pkg - 02 T/A Col Ed.
Engine: 5.0L - 5.7L Ram Air
Hello everyone,
First I would like to say how good it is to be back. I got derailed for over a year from my restoration due to personal matters popping up, but now its all back on track, and I can finally start putting the car back together.
I have a pair of leather seats with powered adjust and lumbar support from a 2002 TA that I am in process of installing in my 91 Firebird. I have the wiring harness that connects the seats together along with the air lines, but I don't have the wire that connects to the fuse box.
In another thread I read that you could run the hot wire from the seats into the back side of the fuse panel in the WDO circuit breaker, but I wanted to make super sure that was were I needed to install it before I burn something up.
I have a picture here of the back of my fuse panel and the blue arrow is pointing to the spot I assume is were the hot wire for the seats should be added. I want the installation to be a close to factory as I can get, so does this seem like the proper spot to connect the wire? I don't know shyte about wiring and fuse boxes so any help would be appreciated.
Net-Viper X
Attached Thumbnails Need help wiring 02 seats into 91 Firebird-fusepanel.jpg
Old Oct 3, 2011 | 07:51 PM
one92rs's Avatar
Car: SOLD!!!!!
Re: Need help wiring 02 seats into 91 Firebird
i found power wires in my center console in which i wired my 2000 seats to for there power.
Old Oct 3, 2011 | 11:31 PM
cookie21's Avatar
Car: 1992 RS
Engine: ZZ4
I just wired mine up 2 weeks ago ill find out where i ran the wire to in the fuse box and let ya know.
Old Oct 8, 2011 | 12:07 AM
sac92transam's Avatar
Car: 92 convertible t/a and 68 firedbird
Engine: 305/402
Transmission: 700r4/turbo400
i just ran a power wire from the battery and added a fuse to it and ground works like a charm never any problem never blown a fuse had it like this for 8 years
Old Oct 16, 2011 | 11:46 AM
l_dis_travlr's Avatar
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
I just looked in the service manual for my 90 Formula.
No info/diagrams on power seats -- only lumbar support.
However...
The the WDO (35 amp circuit breaker) routes power to
power windows.
The Pwr Acc (35 amp cir-br) routes power to the defogger,
power door lock, and lumbar suppoort.
I can't tell if your pic is conveying that you don't have
pwr-wdw, but either of these would be a good place
to get power. Just be sure to use large enough wire to
handle the seat motor current. Hope that helps.
Good luck.
Old Oct 16, 2011 | 01:09 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Just make sure its a hot at all times circuit.Power windows only work with the key on.Lumbar should work w/out the key.Crimp it to the blue (arrow) one & use a fuse.
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
1989formula5.7l
Aug 17, 2015 02:56 PM
Mister_Johnny99
Aug 14, 2015 12:59 PM
