Steering Wheel Swap
Old Oct 18, 2011 | 10:28 AM
inkedbass's Avatar
Steering Wheel Swap
I have a 1990 Firebird Formula Edition, 305 TPI with the 5 speed.
I recently switched to a GT grant wheel and when we took it out for a test spin I noticed some differences.
1) No snap back. You know how when you turn the wheel to make a turn the wheel adjust back to straight? That's not happening now.
2) The steering seems 'stiffer' than before by a considerable amount.
Did we torque down the bolts too much?
Any ideas and input would be GREAT.
J
Old Oct 18, 2011 | 03:14 PM
THETANK's Avatar
Car: 91 rs
Engine: Carbed 355 CR 9:1 xr276 cam
Transmission: 700r4 2600 stall
Re: Steering Wheel Swap
I am about to install a new grant wheel myself. I believe your car had an air bag. I have read that most airbag cars have had to trim back the original plastic on the the car because if not the grant wheel will rub a little , causing the symptoms you have listed. Hopefully all you have to do is shave a little off and you will be fine, maybe someone else who did the install could offer more insight.
Old Oct 19, 2011 | 10:31 AM
inkedbass's Avatar
Sorry for the ignorance but I see a **** ton of plastic. What parts are you describing?
J
Old Oct 19, 2011 | 01:31 PM
THETANK's Avatar
Car: 91 rs
Check this thread out it has pics and can probabbly clear it up for you.
https://www.thirdgen.org/forums/inte...eel-grant.html
Old Oct 20, 2011 | 01:16 AM
inkedbass's Avatar
Thanks!!!
J
Jorlain
Aug 24, 2022 05:11 PM
backtothe80s
Sep 5, 2015 12:39 AM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
mustangman65_79
Aug 9, 2015 03:00 AM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
