RPO D27 (rear compartment security cover),
Old Nov 16, 2011 | 08:29 PM
morries's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Does anyone know where i can get one of these or at least get the dimensions of one so that i can fabricate it?
Old Nov 16, 2011 | 08:31 PM
morries's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Re: RPO D27 (rear compartment security cover),
Old Nov 16, 2011 | 08:50 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
You might consider our site's classifieds. BTW, the security cover requires a different rear plastic piece as well (the piece with the cargo light). This latter has a wider lip where the cover rides.
JamesC
Old Nov 16, 2011 | 11:45 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
i have made a couple of covers (by no means secure) but covers none the less . i used cardboard to make a template of opening . transfered that to 5/16"-3/8" plywood . used 2x2's for 4 legs , 1 on each corner , scrap 1x2's lenghtwise (underside) for center support , paint to seal , scrap cabinet handles to lift up/out , scrap carpet on top . may sound a little "jerry rigged" , but if you take your time and finish it clean it looks good (much better than the big hole) . i have had several people ask me about mine so they can make one . not hard to make , cheap if you scrounge , covers any gear in well , look's good . good luck .
Old Nov 26, 2011 | 10:19 PM
rarebmx's Avatar
Car: 89 IROC/89 Vert/87 Vert/89 GTA Vert
Engine: 5.7/5.0/5.0/5.7
Axle/Gears: 9" 2.77/9" 3:23/9" 3:42
I might be able to come up with one is Grey for you... I do know where one is and I can get the platic panel so that it works. If it were Tan you would not be in luck because it would already be in my car.
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
I'llrocya
Feb 2, 2016 11:43 PM
AmorgetRS
Convertibles
Aug 31, 2015 11:55 AM
Randomtask2
Aug 13, 2015 01:57 AM
