Steering wheel swap
Old Nov 28, 2011 | 02:24 AM
Tidalwave's Avatar
Car: 1991 z28 Camaro
Transmission: 7004R
Steering wheel swap
I'm in need of a new steering wheel as mine is worn and is no longer comfortable to keep a grip on I was just wondering if it is a simple switch and if there are any problems that I should look out for. This is the steering wheel I was looking at http://www.grantproducts.com/products/view/48/
Old Nov 28, 2011 | 06:52 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: Steering wheel swap
if you're in california and have a 91 like your info suggests, you're going to have a hard time passing inspection without an airbag. Some have swapped out the airbag wheels for non, but it does require a bit more work than the older 3rd gens.
Old Nov 28, 2011 | 04:53 PM
Tidalwave's Avatar
Transmission: 7004R
I do live in California, but my car is registered in Arizona (Family's residence). Besides that, would that be the only problem?
Old Nov 28, 2011 | 05:26 PM
91specialk's Avatar
Car: '91 Formula
Engine: 305 TBI
Transmission: Newly rebuilt 700R4
Same here. My wheel is rotting and I hate the look of the huge air bag compartment. Gonna make the switch soon. Just be sure you don't blow your face off with the air bag. Here is a link for disconnecting/removing the air bag. https://www.thirdgen.org/airbag
I'm not sure about any other problems. I'm wondering if the air bag dash light 'INFL REST' would stay on or something...
Old Nov 28, 2011 | 05:37 PM
Tidalwave's Avatar
Transmission: 7004R
I'm sure it will. I've read that the only way to disable that is manually, which the manual tells you how do that.
Old Nov 28, 2011 | 05:42 PM
91specialk's Avatar
Car: '91 Formula
Engine: 305 TBI
Agreed. Another option... the light will burn itself out eventually. My seatbelt light finally died after years of not wearing it
Old Nov 28, 2011 | 06:45 PM
one92rs's Avatar
Car: SOLD!!!!!
2000 steering wheel. changed the connector from stock wheel with solder and heat shrink to new wheel. works perfect along with horn.
Old Nov 28, 2011 | 09:14 PM
Tidalwave's Avatar
Transmission: 7004R
What mount do you have for your gauges underneath the dash, One?
Old Dec 17, 2011 | 02:26 PM
davidj3594's Avatar
Are those 4th gen camaro seats?they look great
Jorlain
Aug 24, 2022 05:11 PM
backtothe80s
Sep 5, 2015 12:39 AM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
mustangman65_79
Aug 9, 2015 03:00 AM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
