water!
Car: 1990 T/A w/WS6
Engine: 5.7L V8 TPI
Axle/Gears: 3.23 w/ posi
water!
hello,
a couple days ago i went inside my car to find a roll of paper towels i had in there soaked, and the carpet to. Any ideas on where the leak could be coming from?
i'd like to get it stopped as soon as possible.
Car: 72 Chevelle
Engine: 468
Transmission: Muncie
Axle/Gears: 355
Re: water!
The Heater Core maybe leaking. Check to see if it is coolant.
Car: 1990 T/A w/WS6
Engine: 5.7L V8 TPI
Car: 72 Chevelle
Engine: 468
Axle/Gears: 355
Re: water!
Ok, I'm assuming you have a T/A. post the year and options (ex; T-tops) maybe someone with the same configuration as yours, will pipe in.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: water!
i had a leak there too, the piece or corrugated tubing that goes form the body to the door with the wiring had pulled away a bit. I fix that, and changed the door seal which was shot and the leak stopped. something to look into
Car: 1990 T/A w/WS6
Engine: 5.7L V8 TPI
Re: water!
Car: 89 Formula, 85 Trans AM & 91 Bird
Engine: 5.0 CARB, 5.7L TPI & 3.1L V6
Transmission: T-5/700R4/700R4
Axle/Gears: 9 Bolt & 10 Bolt X2
Re: water!
Goodness, I've had this problem for three years!
Neglect...
I've pinpointed the leak, what's the rubber seal for the wiring that comes in? It needs to be replaced.
Neglect...
