gta wheel..how to get this black plastic off? under the wheel
Old Dec 26, 2011 | 07:08 PM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
how does that black plastic part come off so i can get to the hub??
Old Dec 26, 2011 | 07:14 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: gta wheel..how to get this black plastic off? under the wheel
You need a Steering Wheel Lock Plate Remover.
Old Dec 26, 2011 | 07:15 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
seriously? -____- whats the point of this stupid thing?
Old Dec 26, 2011 | 07:17 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
how do i use the remover?
Old Dec 26, 2011 | 07:26 PM
mantaguy's Avatar
Engine: 5.0 EFI
I guess It keeps all the stuff safely intact.I'll post an image of it in my photo album(don't know how to post photos in thread)You thread the black part to the column,then you tighten the red handle down to depress the cover,then you have to remove the locking ring that holds the cover.Then you can get to whatever your after.Then you reverse to put everything back.
Old Dec 26, 2011 | 07:28 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
i looked at the two you had of the actual puller but i saw what it looks like on the autozone site..does it thread onto the steering shaft then pulls it up?
Old Dec 26, 2011 | 07:29 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
http://www.ehow.com/how_5583450_use-...e-remover.html
Old Dec 26, 2011 | 07:35 PM
mantaguy's Avatar
Engine: 5.0 EFI
No, it depresses the plate.
Old Dec 26, 2011 | 07:42 PM
mantaguy's Avatar
Engine: 5.0 EFI
Some auto stores lend them to you,unfortunately the one I went to didn't.But it is a good tool to have along with a wheel puller.I think I used them both at least a half dozen times this past summer.
1992 Trans Am
May 10, 2023 07:19 PM
Fronzizzle
Mar 18, 2019 08:29 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
kah992
Aug 19, 2015 02:55 PM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
