Steering Column- What is this Part?
Old Dec 28, 2011 | 06:04 PM
Ghasoline's Avatar
Car: '92 Camaro RS
Engine: 305 tbi
I'm pulling apart my steering column to try and find out why my horn isn't working.
When I finally got the lock plate off, I found that this part of the assembly was broken. It's a piece of plastic that holds some sort of metal pin.
What does this little thing do?
It is part of the horn connection?
Attached Thumbnails Steering Column- What is this Part?-img_0264.jpg   Steering Column- What is this Part?-img_0265.jpg   Steering Column- What is this Part?-img_0267.jpg
Old Dec 28, 2011 | 06:06 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Steering Column- What is this Part?
that is the horn contact button.
Old Dec 28, 2011 | 06:52 PM
Ghasoline's Avatar
Car: '92 Camaro RS
Engine: 305 tbi
Well I guess that explains it. What's the likelihood of fixing it without replacing the whole assembly?
Old Dec 28, 2011 | 06:57 PM
Engine: Lb9
Transmission: M20
replace it !!! rockauto.com the turn signal switches are $30 or take there part numbers and search ebay maybe able to find one for $20 or less
Old Dec 28, 2011 | 06:58 PM
Engine: Lb9
Transmission: M20
http://www.ebay.com/itm/STANDARD-MOT...ht_1532wt_1042
Old Dec 28, 2011 | 07:44 PM
silentkillzr's Avatar
Car: 1984 Firebird (89 Formula Clone)
Engine: 357
Transmission: m29 T56
Axle/Gears: 3.27 9 bolt Borg Warner.
ugh i need todo this on my truck...
Old Dec 28, 2011 | 10:02 PM
Ghasoline's Avatar
Car: '92 Camaro RS
Engine: 305 tbi
Oh wow, that's a lot cheaper than I expected. Thanks for all the help!
Old Dec 28, 2011 | 10:07 PM
Engine: Lb9
Transmission: M20
Double check the part number , pretty sure that's it
Old Dec 28, 2011 | 10:29 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
You need to replace the canceling cam,that part above is not what you need,you need part no.26047013 and is available from GM.
15.75 from GM parts direct,com
Fronzizzle
Mar 18, 2019 08:29 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
