V6 dash swap fuel level gauge question
Old Jan 5, 2012 | 10:15 AM
4.8camaro's Avatar
Car: '89 Camaro
Engine: 4.8, ls9 cam, mpt76
Transmission: Built 4l60e, 3600 stall TC
I have an 89 camaro that I swapped a 4.8 in and just finished the 99 v6 camaro dash install. I've read on here that the v6 (98+) cars had the same ohm resistance as the third gens. Does this mean my dash fuel level gauge is compatible with my fuel level sending unit? Or will the LS PCM not even recognize it?
If the signals of the dash and sending unit are the same but the PCM doesn't recognize the resistance, is there any way I can wire the gauge directly to the sending unit wires, apposed to through the data line?
Thanks in advance
Old Jan 6, 2012 | 05:11 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: V6 dash swap fuel level gauge question
stock 3rd gen gauge is 0-90 ohm. 90 ohms being full, 0 ohms being empty.
pulled this from ls1tech.com:
Sending units & level sensors varied greatly in design through the years, but there were only 2 different level sensor ranges in all Camaro's made.
Up through '97 was 0-90 ohm & '98 up was 40-250 ohm.
Frozer!!!
Jan 19, 2024 04:55 PM
Jorlain
Aug 24, 2022 05:11 PM
86IROC112
Aug 17, 2015 02:00 PM
R3500
Aug 17, 2015 12:16 PM
redmaroz
Aug 16, 2015 11:40 PM
