guage cluster
Old Jan 6, 2012 | 06:52 AM
am muscl's Avatar
Car: 86 Z28
Engine: 67 327cu. dart II heads
Transmission: 700R4 2200 stall
Axle/Gears: 3.73 gears
guage cluster
my 86 Z the only guages working were the speedo and gas guage. i swapped in a cluster from an 84 Z and everything works great except the speedo is 10 miles an hour off. i thought the speedos were all the same and the gear on the tranny is what changes it. so why is it 10 off
Old Jan 6, 2012 | 07:07 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: guage cluster
Originally Posted by am muscl
so why is it 10 off
Constant 10 or does the needle jump around? You may find something below to consider:
https://www.thirdgen.org/forums/inte...eedo-woes.html
JamesC
Old Jan 6, 2012 | 07:15 AM
am muscl's Avatar
Car: 86 Z28
Re: guage cluster
its a constant 10. i will check later and make shure its seated correctly
sheachopper
Jul 31, 2019 11:27 AM
