Fix for T-Top and hatch seals
Old Dec 30, 2011 | 01:23 PM
88 5.7 Iroc-Z's Avatar
Car: 88 Iroc Z, 00 SS
Engine: 5.7 HSR, 5.7 LS1
Transmission: 700r4, T56
Axle/Gears: 3.23, 3.42
Ok, so my car has always let in a bit of water into the trunk area when it rained because the seal had been smashed for so long, and so I decided to take a page out of Ferrari's book and tried using vaseline on the seals, checked this morning after it rained all night and voila, my trunk panels are dry
Old Dec 30, 2011 | 01:30 PM
NowhereFast's Avatar
Car: 87 Trans Am, 99 WS6, 16 Mustang GT
Engine: LB9, LS1
Transmission: 700R4, T56
Axle/Gears: 3.42 Posi, 4.10 Posi
Re: Fix for T-Top and hatch seals
Ferrari does that?
Old Dec 30, 2011 | 02:44 PM
Well they recommended it to owners of older targa top cars as a fix for squeaks and noises, and I figured it would help repel water seeing as its petroleum based (like oil), and help keep the seals from drying out. Also the driveway on our house is at an incline and the t-tops always make noise when i go up it, and yesterday after applying the jelly, the noise was definitely reduced
Old Jan 4, 2012 | 06:54 AM
1991_RS's Avatar
Car: 1989 Formula Firebird
Engine: Swapped 350 TPI speed density
Axle/Gears: 2.73 (soon to be 3.42)
No matter what i do my rear seal allays leaks a little, and my windows freeze to the seal any suggestions. Ive tried the Vaseline last summer it just stopped the seals from drying out further.
Old Jan 4, 2012 | 11:20 AM
82tarecaro's Avatar
New seals
Old Jan 6, 2012 | 01:52 AM
TTA579's Avatar
Car: Turbo Trans Am #579
Engine: 231ci (3.8L) LC2 (Buick Turbo)
Transmission: 200r4
Axle/Gears: Borg-Warner 9-bolt
MOAR! If you're still having issues apply more. Apply enough to cause the excess to transfer, then wipe clean the transfered grease.
A silicone based lubricant (silicone grease) is actually going to going to give you better results. It will have better hydrophobic properties (sheds water) and has a greater effective temperature range. It will give the appearance of revitalization in rubber parts as giving them a like-new look and feel. This won't last forever and reapplication is necessary, but it'll be cheaper than replacing those pieces.
Old Jan 6, 2012 | 06:58 AM
1991_RS's Avatar
thanks ill try the silicone grease then maybe replace the seal in spring if it still leaks. I am having problems with my doors freezing to the body and window to the seal will the grease help with that.
Old Jan 6, 2012 | 09:37 AM
TTA579's Avatar
Transmission: 200r4
The silicone grease should keep your door/window from freezing. Make sure you cover all of the door and window seals.
Street Lethal
Apr 30, 2019 12:14 PM
1Aauto
Sponsored Vendors
Apr 9, 2018 03:00 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:14 PM
1Aauto
Sponsored Vendors
Aug 24, 2015 03:40 PM
