Painted some interior parts.
Old Jan 9, 2012 | 07:27 PM
mtvd23's Avatar
Scored some 82 door sills off a T/A this weekend at the local U-Pull it and a set of seat belt holders. Painted them black along with the back seat side panels. Here is the before and after. I am very happy with how they came out. I used the Dupli-Color Vinyl and Fabric Spray paint in flat black.
Attached Thumbnails Painted some interior parts.-cam2.jpg   Painted some interior parts.-cam3.jpg   Painted some interior parts.-cam7.jpg
Old Jan 9, 2012 | 07:51 PM
ZZ3 Z28's Avatar
Car: 1986 Z28
Engine: ZZ3
Re: Painted some interior parts.
What did you do to prep them, any primer? I would think a thin coat is better than a thick coat on something like this, yes?
Old Jan 9, 2012 | 08:20 PM
mtvd23's Avatar
I gave all the parts a bath with dish soap. Then did about 6 or 7 very light coats, waiting a couple minutes in between each coat. Thin is much better than thick. I tried to follow this thread as close as possible. https://www.thirdgen.org/forums/inte...ic-carpet.html Also used a prep spray on the back seat side panels because the plastic was so dry. The vinyl and fabric spray doesn't really require any primer, just a very clean surface. The end result looks like they were always the new color, doesn't look bad at all.
Old Jan 9, 2012 | 11:53 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Looks good there mtvd.good job.
Old Jan 10, 2012 | 09:04 AM
ZZ3 Z28's Avatar
Car: 1986 Z28
Engine: ZZ3
Are you going to give them a shot of clear, also?
Old Jan 10, 2012 | 09:24 AM
IROC#1's Avatar
Car: 1988 IROC Z
Engine: 5.7 litre
Axle/Gears: 3.27 Posi with 4 wheel disc brakes
Looks good now and I hope it lasts...Ive seen people paint interior plastics in the past and unfortunately the paint starts to chip and then you have to repaint or eventually replace the plastics.
Old Jan 10, 2012 | 10:11 AM
mtvd23's Avatar
Thanks, From what I've read about this paint and how it looks right now I don't think it will chip. IMHO it looks like the plastic is black and not painted(My best paint job to date). I hope it last too. This is not my first paint job and I've learned a lot along the way, the lighter the coats and the better the prep the less likely you are to have issues, patience and decent paint helps a lot too.
Old Jan 10, 2012 | 10:52 AM
mantaguy's Avatar
Engine: 5.0 EFI
If you did a prep job, cleaning,adhesive promoter,I would not worry about the paint coming off.You might see some wear on the sill plates down the road because of the color change,were it's located,people stepping on them.All the other pieces I wouldn't worry nobody touches that area,just be careful putting stuff in the cargo area.
I did mine this year but I didn't change the color,Carmine on Carmine.
Good Job
Vintageracer
Jan 10, 2020 05:33 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
IrocBuzz
Camaros Wanted
Nov 20, 2015 11:29 AM
g.l.mos
Aug 22, 2015 12:02 AM
Exxon Limited
Aug 9, 2015 08:13 PM
