Air Bag wire
Old Jan 13, 2012 | 09:06 PM
vjgillespie's Avatar
Car: !991 RS Camaro
Axle/Gears: 4.10 4th gen
Air Bag wire
I have the steering column out of my 1991 camaro that I was going to try and sell but when I pulled the steering wheel I found that the previous owner had cut the plug off that goes to the air bag. Just curious if there is a way to either repair or replace the wire. The column is in good shape other than the wire I just installed a 4th gen column in the car . Thanks
Old Jan 14, 2012 | 09:41 AM
Car: !991 RS Camaro
Re: Air Bag wire
bump
Old Jan 15, 2012 | 09:21 AM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: Air Bag wire
i would just relace the entire airbag ring and the wire running through the column than try to repair it. the last thing you want is a short in that circuit......or sell it to someone whos running a non airbag wheel.
Old Jan 15, 2012 | 10:37 AM
Car: !991 RS Camaro
Re: Air Bag wire
Thanks, I will try that. I wasn't sure if you could replace just the wire.
Old Jan 15, 2012 | 11:25 AM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Re: Air Bag wire
There is also a procedure for setting airbag clock spring...
(since it has only so much coiled wire in it)
Old Jan 15, 2012 | 11:27 AM
travis401's Avatar
Car: 91 Camaro RS
Re: Air Bag wire
i dont remember if i pulled mine or not. i think i left it in there...
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
Caspar
Jun 19, 2016 11:19 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
87350gtanj
Aug 8, 2015 10:32 AM
