Gauge Cluster
Car: 1990 RS
Transmission: Built-700R4
Gauge Cluster
I looked around at all the websites that I know that sell 3rd gen parts & cannot find a place that sells reman gauge clusters? I did not find any place that sells new ones either (except the custom kits from Hawk's, but those are $900 + dollars...
So, does anyone know a place that does one of the following:
1. Sell remanufactured gauge clusters?
2. Rebuild mine for a charge?
3. Sell a new one outright?
Or is this pretty much a fix my own or junkyard type deal......?
).So, does anyone know a place that does one of the following:
Re: Gauge Cluster
That's actually a good q. I've looked around many e-tailers and car mags and have found no factory oem gauages available. Yea, what do you do if you have to replace a combo tach/oil pressure gauge on a mid '80s Z? Any one?
Car: 1990 RS
Re: Gauge Cluster
My tach is pegged all the way to red line & does not move. The speedo only works after I've had the car running for 10 + minutes....weird!
In two weeks I'm going to pull the entire cluster & take a crack at it....I can't make it any worst.....maybe....
I've got a buddy that says he can fix the tach, he is an electrical engineer & has a 3rd gen, he told me his car had the same issue & he knows a solution. I'm going to try a new speedo cable & see if that fixes the speedo......wish me luck!
Car: 1990 RS
Re: Gauge Cluster
Car: 1990 RS
Re: Gauge Cluster
I just found this place doing a google search:
http://www.ddinstruments.com/index.p...d=12&Itemid=61
I'm going to give them a call tomorrow. They list the 90 thru 96 camaro at $239 for the cluster. I'm going to check what all is included.
Found this one also:
http://www.instrumentclusters.com/
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: Gauge Cluster
By the way, you don't have a speedo cable. I've sold several clusters for your car on here for less than $100 tested first in my car before doing a deal, but I don't have one right now. Might be able to find one in the next few weeks if you don't have any luck with your search and you would go for a used one that works. LMK, Henry
Car: 1990 RS
Re: Gauge Cluster
If you find one that works let me know, I will def try to repair mine in 2 weeks.
Re: Gauge Cluster
Thanks for the links. Good to know.
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: Gauge Cluster
Hi, found one that looks good, but have not tested yet. Still need one of these? LMK and I can test it. PM or email me your email for pics and other info, Henry
Car: 1990 RS
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: Gauge Cluster
oem gauges are to be had,if you keep at it.i got a new old stock from a chevy dlr in nebraska.but there are companys that rebuild gauges ,one is autoinstruments.com.
