New Vacuum Selector Valve Defective Out of the Box
Car: 1991 Camaro RS
Engine: 305 TBI
Transmission: 4AT
So I had the hissing in the center console and couldn't change airflow from defrost to the center vents. I did a search here, found the info on the Vacuum Selector Valve, took the center stack apart and sure as heck that thing was leaking. I'm a service manager for an independent repair shop, so I asked the parts manager to call the Chevy dealer and find one. They told him it is no longer available, but a local AC Delco parts vendor had one in stock.
I plugged the valve in and it leaks worse than the one I took out
The case halves (between the dial and the body) leak like crazy when the thing is plugged in. Anyone else run into a NIB bad valve? I feel like I did it wrong or am just super unlucky. We'll try and find another one, but is there some kind of other fix for this?
. The case halves (between the dial and the body) leak like crazy when the thing is plugged in. Anyone else run into a NIB bad valve? I feel like I did it wrong or am just super unlucky. We'll try and find another one, but is there some kind of other fix for this?
Car: 1991 Camaro RS
Engine: 305 TBI
Transmission: 4AT
Re: New Vacuum Selector Valve Defective Out of the Box
Welp, I figured it out on my own. I took the original one apart to see what makes it tick. Then I checked out the defective one and it was fairly apparent...evidently the tabs at the end of the center pin were both cracked and broken so it wasn't a tight fit between the two case halves.
I hate that crap, when some ***** breaks a part and then returns it to the parts supplier without telling them its broken. Then I get to reap the benefits of that same *****'s dishonesty when they re-sell it to me. It's only 15 bucks, but its nice of them to take it back. Hopefully it doesn't end up back on the shelf!
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Another reason I swaped my 85 non AC setup in my car so I only have to rely on cables if they dont break LOL
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
I thought that kind of stuff only happened to me.
backtothe80s
Sep 5, 2015 12:39 AM
