Pedal/Clutch Assembly Help!
Old Jan 25, 2012 | 10:08 PM
Honda4lyfe's Avatar
Car: 1985 Camaro Berlinett RS
Engine: 305 FI
Iam swapping a t5 out of an 85rs into an 89 irocz which was an automatic for a buddy...everything is going well until i get to swapping the pedal/ Clutch Assembly. Steps For the procedure would be very nice please help!
Old Jan 25, 2012 | 11:49 PM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Re: Pedal/Clutch Assembly Help!
from under the dash
- take off the clip for the brake pedal
- undo the brake booster bolts and the 1 bolt at the top of the peddles so 5 in total
- take out the auto brake pedal
- swap in manual peddles and go back in reverse
Old Jan 26, 2012 | 12:01 AM
Honda4lyfe's Avatar
Engine: 305 FI
What about the hydraulic clutch pedal/slave cylinder assembly
Old Jan 26, 2012 | 12:15 AM
6SIX6's Avatar
Car: 89 IROC
I thought you already had that in
Booster has to come out then and you have to put 2 bolts in the upper booster holes to hold the pedals. You will see it in the pic at the bottom
The pedal assembly you have should have to bars that come down and bolt to the firewall. Well those two arms are bolted to the firewall with the "U" bolt that holds the master to the firewall in the enginebay. I put both arms against the firewall once the pedals where in and use the u bolt to hold them the right distance apart. marked the 2 holes on the firewall and drilled them.
Next would be to cut the hole in the firewall for the master to connect to the clutch pedal. The hole for the master will not be round but more egg shapped.
Heres a pic of what it will look like when its done. I had to make a shim for mine just to make it a little straighter and also I messed the hole abit so I needed to cover it to prevent water coming in
Old Jan 26, 2012 | 12:19 AM
6SIX6's Avatar
Car: 89 IROC
AS you can see by this pic i messed the holes being spot on abit. It happens oh well
You can see the bars that attach to the firewall in this pic. they are behind the pedals
Old Feb 5, 2012 | 04:44 PM
chrispy383's Avatar
Car: 92 rs 25th ann.
Engine: 383
Axle/Gears: 342
I also have done this swap, you should also weld another piece of sheet metal @3" by 3" over the spot and re make holes again. The stock cars double up the thickness for extra support. This way firewall doesn't flex when pushing on clutch pedal.
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
skinny z
Oct 5, 2015 06:23 PM
gord327
Oct 3, 2015 01:25 PM
Dragonsys
Sep 25, 2015 03:51 PM
