Inner door handle replacing
Old Mar 29, 2012 | 03:11 PM
motokid108's Avatar
Car: 88' IROC Z.
Engine: 305 TBI.
Transmission: T-5 5 Speed manual.
Axle/Gears: Stock 3.08's I suspect.
I'm currently working on an '88 IROC i bought that seems plagued with problems. Currently i need to replace the door handle on the inside since it broke. I bought A Chiltons repair manual, but it doesn't say anything about removing/replacing the inner door handle. Does anyone know how to replace it? Any and all help would be greatly appreciated. Thanks in advance.
Old Mar 29, 2012 | 03:58 PM
TheMonster's Avatar
Car: 1983 Z28
Engine: Forged 355
Re: Inner door handle replacing
Pop the door panel off, and it's pretty easy to tell how to replace it
Old Mar 29, 2012 | 06:22 PM
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
You just have to drill out the rivet(s) and disconnect the rod. I replaced mine with an aftermarket one. Mistake. Really weak spring and it would not snap back into place. Get one from the OEM or the junkyard...
Old Mar 29, 2012 | 07:09 PM
magicmerlin's Avatar
Car: 89 RS -95 camaro sc
Engine: 2.8 - 3.4
inside door handle costs about 20 bucks at autozone
Old Apr 3, 2012 | 12:20 PM
motokid108's Avatar
Car: 88' IROC Z.
Engine: 305 TBI.
Thank you. I had the panel off and couldn't tell if it cam off from the rivet on the metal bracket, of the pivoting rod through the handle itself.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
86IROC112
Apr 9, 2016 10:20 PM
NBrehm
Aug 25, 2015 11:49 PM
BlackTopKing
Aug 19, 2015 12:13 PM
