rusty bolts on hatch glass
Old Apr 6, 2012 | 10:46 AM
camaro211z28's Avatar
Car: 92 camaro RS
Engine: vortec 350/396
I just noticed the 4 bolts that hold that hatch on at the top of it are all rusted up but had a plastic cap over them. anybody replaced these before or are theybeven replacable?
Old Apr 6, 2012 | 10:54 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: rusty bolts on hatch glass
You can pop them out one at a time and replace them without upsetting the hatch alignment. New ones are available through Hawks or Modern Day Muscle. Another good option is finding non-rusted used ones.
Old Apr 8, 2012 | 09:46 PM
gotabekidding's Avatar
Car: 91 & 88 GTA, 89 Formy, 89 bird
Engine: 3 - 350 TPI, 305 TBI
Transmission: All 700R4's
Axle/Gears: unknown
If you found a set at the junkyard, you could send them to be powdercoated and replace them one at a time.
As was said by "naf"
Old Sep 28, 2017 | 05:31 AM
cunningr's Avatar
Car: 1990 Camaro RS
Transmission: Automatic
mine are rusty as well and when i attempt to loosen the nut the whole bolt spins. How did you get yours out??
Old Sep 28, 2017 | 06:36 AM
kentuckyKITT's Avatar
Car: 2 T-Tops
Engine: 327/305
Transmission: TH350/700R4
Axle/Gears: 3:42/2:73
If the whole bolt is spinning, the only way I know how to get them out is do this: use masking tape around the glass and carefully grip the edge of the bolt with a pair of vice grips and with your wrench or socket underneath, slowly turn the nut. The vice grips will damage the plastic coating on the bolt, but if the bolt is junk, it won't matter. Being as it spins in the glass with the nut, the bolt is junk as the hex portion in the glass has rusted almost round allowing it to turn. When you get new ones, they will have a nice hex formation that prevents it from turning while you tighten it down. As someone else said, do one at a time.
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
Uglybronco
South Central
Oct 25, 2015 09:22 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:14 PM
BrianI
Aug 9, 2015 11:52 AM
