Hatch Pull Down Assembly Linkage
Old Apr 19, 2012 | 09:51 PM
1983Chimaera's Avatar
Car: 1988 Camaro IROC-Z
Engine: LB9 (305 TPI)
Axle/Gears: 2.73 Positraction
I have an '88 LB9 IROC-Z I'm restoring, and unfortunately one of the previous owners decided to half-a$$ delete the rear hatch pull down unit. The sliding latch had been JB Welded in place, and the pull down motor and linkage is long gone. I went to the local Pick N Pull today and found 2 replacement pull down motors (they're everywhere in Buicks and Cadillacs!), but the linkage itself used in those applications appears to be different than what I can make out in the few pics available online for the 3rd gen unit. I'm going to try to make it work, but I would match rather find the correct linkage. I know I can get replacement nylon guides, but the metal linkage to the sliding assembly doesn't seem to have any supplier. Does anyone know of any sources?
Old Apr 19, 2012 | 10:08 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: Hatch Pull Down Assembly Linkage
Lift rod?
Old Apr 20, 2012 | 09:38 AM
Found it, thanks for the PM! Turns out it is similar to the Buick / Cadillac lift rod, but I'm going to order the correct Camaro / Firebird one from TDS today. Thanks again!
Vintageracer
Jan 10, 2020 05:33 PM
AmorgetRS
Convertibles
Aug 31, 2015 11:55 AM
86IROC112
Aug 31, 2015 07:00 AM
zayne0
Aug 24, 2015 07:22 PM
madsv1000
Aug 20, 2015 06:45 AM
