How to remove tilt lever and cover?
Old Apr 29, 2012 | 11:39 AM
cdoyle's Avatar
Hi,
So I've read here on the forum that the tilt lever is removed by turning couter clockwise? Is this correct, I cannot get this thing to budge. I have 2 columns and can't seem to get it off of either one.
Also how do you remove the cover that goes around the tilt and multifunction lever? I can't seem to figure out how it comes off, is there a trick to getting that off?
Old Apr 29, 2012 | 12:07 PM
82tarecaro's Avatar
Re: How to remove tilt lever and cover?
The tilt lever unscrews. The cover is removed by disassembling the whole column. It is actually the housing and not a cover.
Old Apr 29, 2012 | 12:19 PM
cdoyle's Avatar
I'll keep trying on the levers, they must just be really tightened down.
I had to go back out and look at the column again, I didn't mean to include the mutlifunction lever.
But the tilt lever appears to have cover that comes off, see pic.
Does this piece come off?
I need to fix the high beam linkage and I think it's all behind this cover. I really hope I don't have to disassemble the entire column to fix this
Old Apr 29, 2012 | 02:22 PM
cdoyle's Avatar
So is the whole tilt lever supposed to unscrew from the column? Or does just the end come off? On my parts column, I finally tried some vice grips on it, and the end came off.
That left an exposed metal piece, and I tried twisting that and it just started to bend. the part that goes into the actual column does not twist at all.
Is that right?
Old Apr 29, 2012 | 02:54 PM
cdoyle's Avatar
nevermind, I was able to get it off on my other column, but geeze do they make sure that those never come loose.
Vintageracer
Jan 10, 2020 05:33 PM
I'llrocya
Feb 2, 2016 11:43 PM
NBrehm
Aug 25, 2015 11:49 PM
3rdgenparts
Aug 8, 2015 07:09 PM
