4th gen daash swap help
Old May 14, 2012 | 07:45 AM
firebirdfreak87's Avatar
Car: 87 firebird did V8 swap
Engine: sbc 350
Transmission: 700r4 shift kit and stall
ok im gonna buy a 4th gen dash and can i use the wiring thats already in the car to wire up the dash plz help before i waste my money
Old May 14, 2012 | 12:59 PM
JacobIroc's Avatar
Car: 92 RS 25th Anniversary
Engine: 305 TBI -> 305 TPI
Transmission: T5/T56
Axle/Gears: 3.08 - 3.73+ soon
Re: 4th gen daash swap help
I think it depends on what dash it is, along with what cluster and what engine youbare running. Search for "4th gen swap guide".
Old May 14, 2012 | 11:30 PM
Engine: sbc 350
well I'm in the middle of doin a 2.8 to 350 swap and figured that dash would look good
Old May 20, 2012 | 09:21 AM
krzyz's Avatar
Car: 1982 z28
Engine: 383
Transmission: 4l60e
Axle/Gears: 3.73 posi
you can run the wires you have in the car already, you would need to splice the 4th gen light switch into ur stock harness and also are u goin to make ur own gauge cluster or run the 4th gen cluster?
Old May 20, 2012 | 11:14 AM
JacobIroc's Avatar
To add onto kryz, if you do a search there is a thread that should answer all your questions. From what i understand you need to use a 93-97 firebird cluster if your dash is 98+ and your are not using a lsx type engine.
Old Jun 9, 2012 | 08:46 PM
1SICK90RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: Stock
use the 97 and down firebird cluster, and get the plugs from the cluster, and get the headlight switch as well
Casey Meyers
Mar 2, 2016 10:46 AM
transam84
Exterior Parts for Sale
Aug 14, 2015 08:54 PM
sreZ28
Aug 14, 2015 07:48 PM
