cut/mystery wires
Old May 26, 2012 | 11:42 AM
blackbeauty89's Avatar
Car: 1989 Pontiac GTA/2007 TrailblazerSS
Engine: 350 L98/LS2
Transmission: 700-R4/4L70E
Axle/Gears: 3.27/4.10
cut/mystery wires
i have some pics of wires and need to see if anyone knows what they are?
File Type: jpg
Old May 26, 2012 | 02:58 PM
Andrew James's Avatar
Car: 1990 Formula Firebird
Engine: 350 (5.7) TPI
Transmission: WC T5
Axle/Gears: 3.42 POSI
Re: cut/mystery wires
Does your radio work? Looks like the antenna cable.
Old May 26, 2012 | 07:34 PM
Engine: 350 L98/LS2
sure does. just fine
Old May 28, 2012 | 01:07 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Can't really tell what the cable is in the other 3 pics without a shot of the end. It could be the pull-cable for the heat temperature control door, antenna cable, or any number of other things. May also be a power cable for an amplifier or something that someone added at some point.
The gray box in the last pic is the VATS module. It's SUPPOSED to be bolted to the ducting behind the center of the dash (don't know why it's zip-tied where it is).
Old May 28, 2012 | 05:38 PM
Cadaver Puncher's Avatar
Car: 92 rs daily driver work in progress
Engine: 3.1 , 204/214 cam
Transmission: 700 r-4, b& m megashifter
Axle/Gears: I want a posi with rear discs
Looks like the radio harness.
Is it factory or aftermarket? If was aftermarket maybe the PO connected it the different.
Old May 29, 2012 | 06:18 PM
Engine: 350 L98/LS2
It's aftermarket. The orig. radio harness is cut up too
Old May 29, 2012 | 06:49 PM
Coyote850's Avatar
Car: '83 Z-28
Engine: 5.0 CFI
Where does the wire connect to, the fuse panel? Could possibly be a fuse is/was being bypassed.
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Bert87
Aug 23, 2015 03:50 PM
