Gauges wont work help!!
Car: 1987 Iroc Z/ 1983 iroc z
Engine: 305 carb/ LT1 750 dbl pmp carb
Transmission: 700r4 shift kit both
Axle/Gears: 3.73 both
Recently put in a new 700r4 trans into my z but after i plugged up the 4 pronged wire right above the linkage my oil pressure volt rpm and fuel gauges stopped working i checked the fuses and even unplugged the wire on the trans but still nothing is there a wire i might have pulled off anywhere? any help would be appreciated.
Ghettobird52
Jul 5, 2024 11:18 PM
