What's this?
Old May 30, 2012 | 10:19 PM
puma1552's Avatar
What's this?
I was getting in my car this morning and I noticed this broken spring, soft sleeve, and broken piece of plastic poking out from underneath the back of my driver's seat:
Is this some type of seat spring that broke? I tested my seat adjustments and they work as they should; I was steaming the seats/carpet the other day so I had an extractor nozzle under the seat but I don't recall hitting anything, certainly not hard enough to break anything and I probably would've heard/felt it...but I also am 99% certain that hasn't been hanging out under my seat for the last 13 years either, since I know at some point(s) in time I've gotten under the seats to make sure there is no loose items underneath.
What is it?
Old May 30, 2012 | 10:35 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: What's this?
Slide spring for adjusting front to back. The " net " covers the spring so nothing gets caught in it
Old May 30, 2012 | 10:37 PM
puma1552's Avatar
Re: What's this?
Thanks, how many of these are there? My seat still slides back and forth with spring tension.
Old May 30, 2012 | 10:44 PM
Car: '87 Camaro
Re: What's this?
PM me a cell # or email addy & I'll send a pic
Old May 31, 2012 | 07:40 AM
puma1552's Avatar
Re: What's this?
Thanks for those pics, those helped quite a bit.
Old May 31, 2012 | 07:42 PM
Car: '87 Camaro
Re: What's this?
It connects to the seat rail with a hook end,
the other end is j shaped, hooks to the ear on the slider.
This is on the OUT SIDE of the assembly.
There is a small spring with both ends j shaped.
1 end hooks to the seat rail, the other hooks to the tab of the slider handle.
This is INSIDE the assembly. ( I'll send a pic )
The tab on the handle that goes thru both the rail & slider is strong enough to hold the seat in place, HOWEVER, if the smaller spring on the handle breaks, it takes VERY little effort // force to move the handle, disengaging the tab from the rail // slider.
IDK what the result of that would be. Maybe a lil wiggle // front to back movement?
