Plastic Seats and still access rear
Old Jun 8, 2012 | 01:23 PM
unknown_host's Avatar
Car: 1989 Iroc Z L98
Hey guys,
I am looking to get rid of my stock power seats (from what I understand, 55 lbs a piece) and am looking to get a set of summitracing or equivalent plastic seats.
What I am trying to find is if anyone has seen or made brackets for these seats to allow them to slide or tilt forward far enough to still allow access to the back seat?
On my old car, I had summit high back plastic seats and a roll cage, so there was no way to access the rear. Now I am wondering if I can keep my rear seats and design a bracket to allow access to that area.
Thoughts?
Old Jun 8, 2012 | 02:28 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
Re: Plastic Seats and still access rear
you can use a few diff seat brackets from GM to work on aftermarket seats.
the power seat rail is only about 12 lbs more. then the non power seat rail.
it's a few hrs of work. but can be done..
Old Jun 8, 2012 | 02:42 PM
I am more thinking about something that would allow the seat to flip forward and grant access to the rear of the car. I get what you are saying, and I could build something similar, but I am wondering if anyone has successfully kept and accessed their back seats with racing style front seats.
Old Jun 8, 2012 | 04:38 PM
Richboll's Avatar
Car: 89 Black IROC-Z convertible
Engine: 305 TBI
Won't the belts be a problem?
Old Jun 8, 2012 | 05:02 PM
That's a very good point.
Old Jun 11, 2012 | 09:41 PM
Dels383TA's Avatar
Car: 84 Trans Am
Engine: 383 Stroker
Transmission: 5 Speed
Axle/Gears: Ford 9"(Moser),4:11s,locker,31splin
The Factory seat belts wont be a problem, they mount to the body of the car and mnot to the seat, if you are running a 5 point harness that wil be a problem as they should be tied into the cross bar of a cage so that they dont pull down in the event of a crash, they should pull straight back.
Old Jun 11, 2012 | 10:24 PM
Richboll's Avatar
Engine: 305 TBI
Not sure that I understand your intent. If you want racing seats, I'd assume that you are going to do some racing and would have racing style "H" or "Y" (3 or 5 point)seat belts. If you aren't, why have racing seats? As I'm sure that you know, most plastic/steel racing seats have holes for racing belts. If you just want the "look" you are correct that you can use the stock seatbelts remembering that belt angles come into play if you are involved in an accident. That being said, it's your ride and you should have it the way you want it. You might want look at some off-road jeep-like stuff that just have a hinge to enable you to flip it forward but I'm not sure if it has the same mounting integrity as a stock seat.
Old Jun 12, 2012 | 09:48 AM
I am 6'6" and my head currently touches the headliner / t-tops. I had the problem on my last Camaro which was an 82. I fixed the problem with plastic seats mounted pretty much on the floor.
So my goals for switching the seats are more head room, I need like an inch and a half or two inches since I will eventually be wearing a helmet in the car. Also, stock power seats = 110 pounds, aftermarket seats should weigh half of that or less.
Old Jun 12, 2012 | 09:57 AM
And obviously I am not doing this for the look of racing seats, if I fit in the stock seats I would leave them alone. I am probably less safe with my head touching the roof than I would be with something modified. I don't plan on putting a cage in this car, so I doubt 5 point harnesses are an option.
Old Jun 12, 2012 | 01:00 PM
Richboll's Avatar
Engine: 305 TBI
Got it. Yes, height can be a problem in the 3rd gens. How about these low profile slider mounts for Poly seats...http://www.jegs.com/p/RCI/RCI-Poly-S...63818/10002/-1
I'd still be concerned about the seatbelt angles and where the belts cross your body in the event of an accident
Old Jun 13, 2012 | 08:57 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Originally Posted by unknown_host
Hey guys,
Thoughts?
I think your looking for this type of seat,this is in my 33 Ply.the passenger seat lifts forward.But I don't know what type of vehicle they came out of.
I'm thinking a van.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
MORREALE5
Sep 13, 2015 09:16 PM
scottmoyer
Interior Parts Wanted
Aug 9, 2015 10:18 PM
