somone tried stealing my camaro, help with ignition cylinder replacement?
Old Jun 10, 2012 | 12:37 PM
Blue1990camaro's Avatar
ok so this morning i come out to find my ignition cylinder broken and a key broke off in it, just the black part u turn is snaped off, column is fine, i bought a new lock cylinder, anyone give me a quick run down on how to install it?
its a 1987 Sport Coupe no tilt or key release
Old Jun 10, 2012 | 01:22 PM
FireDemonSiC's Avatar
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
Re: somone tried stealing my camaro, help with ignition cylinder replacement?
You need a steering wheel puller and if equipped with a tilt column a tool to compress the snaprings that secures the locking plate (You can get by with two small sized standard screwdrivers).
Look up a guide on how to fix "Tilt column wobble" and it will have everything you need to know.
You have to tear the column down far enough to access the screw that holds the ignition cylinder in place.
Old Jun 11, 2012 | 02:08 PM
thanks alot, actualy wasnt to bad bc i dont have tilt lol, new ignitions in and working great, wish i had the vats system tho i love that about the 90+
Old Jun 11, 2012 | 02:48 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
You're fortunate not to have VATS. Ask anyone that has it. Breaks often leaving you stranded all over the place. Most people end up bypassing it anyway to avoid having to deal with it
Old Jun 11, 2012 | 03:22 PM
ZZ3 Z28's Avatar
Car: 1986 Z28
Engine: ZZ3
There was a thread around here some where with the same question and I think the hardest part was getting to the screws that are inside the steering column. You need to pull off the wheel and remove some of the bits in the way to get at them. Then it supposedly slips out real easy like.
Old Jun 11, 2012 | 04:00 PM
basically all i did was
1.) remove horn button
2.) remove steering wheel hold down nut
3.) use puller to pull wheel off
4.) push the black plate down to remove snap ring then remove plate and spring
5.) remove screw holding the mechanism for the turn sig switch (L shaped peg with a circle on the end)
6.) remove screws holding the white plastic bracket (not sure what it is but ull c it its like a collor inside the column)
7.) pull color out and over the main shaft the steering wheel was on, be carefull not to rip the wiring for the turn sig switch and wipers
8.) screw holding ignition cylinder is now accessible, remove screw and slide ignition cylinder out
Re-installment is just the reverse, took me about 30 minutes
Old Jul 16, 2012 | 09:34 PM
Trevmust's Avatar
Car: 1986 Firebird
Engine: 5.0L V8
On summit racing there are two different ones... one being $20 and the other being $26.... I dont know which one to use? They both replace different GM parts but both are firebird applicable....
db057
Aug 22, 2015 08:17 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
