removing rear seats... help please
Old Jun 25, 2012 | 08:04 AM
jloomis95's Avatar
Car: 1992 CAMARO RS 25TH ANNIVERSARY
Engine: 3.1 V6
Transmission: AUTOMAGIC
Axle/Gears: STOCK
Hello, I am currently stripping a 92 3.1 v6. This car has split rear seat. I removed everything but i can't figure out how to remove them from the pegs toward the middle of the seats. Hopefully someone knows what i am talking about and give me a hint to these thing haha. Thanks for any info!
Old Jun 25, 2012 | 09:50 AM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Axle/Gears: 3:27 BW 9 bolt
Re: removing rear seats... help please
I believe you remove the outer screws and brackets first, then they slide off the pegs.
Old Jun 25, 2012 | 10:32 AM
ROCmy86's Avatar
Car: 86 IROC
Engine: 355 Stealth Ram
i just did this to my 86 iroc once you unbolt the seats fold them toward you and wiggle and theyll slide off those center pegs
Old Jun 25, 2012 | 10:54 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Correct. It helps to tip the seat forward, then rotate the seat towards you clockwise for the drivers-side, CCW for the passenger-side to slip it off the peg.
Lon
Old Jun 25, 2012 | 12:14 PM
jloomis95's Avatar
Engine: 3.1 V6
Axle/Gears: STOCK
Alright thanks ill give a try and let you know how it came out!
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
I'llrocya
Feb 2, 2016 11:43 PM
3rdgenparts
Aug 8, 2015 07:09 PM
z28addict8490
Aug 7, 2015 08:48 PM
