Seat belt trim
Old Jun 24, 2012 | 04:23 PM
James76's Avatar
Car: 1984 Camaro Sport Coupe
Engine: 2.8l v6 soon to be 350
Transmission: auto
Seat belt trim
I searched but didn't come up with anything conclusive. I recently bought a new (to me) black interior. I dropped the headliner to recover it as well, and realized the seat belt trim that snaps around the belt is not removable. The trim appears to have been installed before the belt was sewn to the latches and mounted in its hardware. Problem is the set of belts I got is missing one of these trim pieces. Now I could dremel one of the old one's off making just a slit in it to allow the belt to slip through, but is there a better way?
Old Jun 24, 2012 | 08:21 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Seat belt trim
If your talking about the trim that clips to the headliner!!!that's the way to do it,put a thin slit in it.
Old Jun 24, 2012 | 10:30 PM
James76's Avatar
Transmission: auto
Re: Seat belt trim
I hate havin to modify, but we gotta do what we gotta do. A small slit is better than no trim at all. Thanks for the quick answer.
Old Jun 24, 2012 | 10:32 PM
James76's Avatar
Transmission: auto
Re: Seat belt trim
What I can not figure out is these are sold on ebay and even NOS with no slit...how in the world would you get that on there without cutting the belt stitching or the new trim piece?
Old Jun 24, 2012 | 10:47 PM
mantaguy's Avatar
Engine: 5.0 EFI
Re: Seat belt trim
I quess you have to remove the stitching on the belts then have them resown.
Old Jun 24, 2012 | 10:53 PM
James76's Avatar
Transmission: auto
Re: Seat belt trim
I don't suspect there will be a real fix other than buying another belt with the trim already in place. Oh well. Not going for a concourse resto here, just an above average refurb.
Old Jun 24, 2012 | 10:58 PM
mantaguy's Avatar
Engine: 5.0 EFI
Re: Seat belt trim
Iv'e seen some with the cut in them!!!really hard to see,unless your looking for it.Cut them with a jigsaw,thin blade.
Old Jun 24, 2012 | 11:37 PM
camarosrock1989's Avatar
Car: 1989 Camaro RS--
Engine: MPFI
Re: Seat belt trim
You have any pics, would like to see what you are talking about.
Old Jun 25, 2012 | 03:39 PM
Hal87's Avatar
Car: '84 Firebird TA & '87 Camaro LT
Engine: 350 V-8 & V-6
Axle/Gears: 3.23 & 3.42
Re: Seat belt trim
I believe you can 'unthread' the seat belt from the reel in the roof and slide a new one on, then rethread the belt. Not sure I want to mess with that assembly though. I just used a razor saw to make the slit in the ones I put on, doesn't show very much, no one looks there anyways
Old Jun 25, 2012 | 03:48 PM
James76's Avatar
Transmission: auto
Re: Seat belt trim
well I posted another topic, that particular belt is locked in the retracted position..
Old Jun 25, 2012 | 05:04 PM
mantaguy's Avatar
Engine: 5.0 EFI
Re: Seat belt trim
No,can't do that either!! it looks like a ratchet tie down in their,they stick the belt in the slot and loop it,then it is sown in their also
The only way to get that trim piece in without cutting it, is to cut the threading,put in on,then resow itjust take it to your local upholstery shop!it will only take a couple minutes.
RyanJB
May 7, 2016 06:23 PM
codeysabatini
Sep 20, 2015 11:36 AM
MORREALE5
Sep 13, 2015 09:01 PM
iroczguy86
Sep 13, 2015 02:22 PM
MORREALE5
Sep 10, 2015 08:58 AM
