Another dash post
Car: 92 camaro RS
Engine: vortec 350/396
Another dash post
Just wonder what you guys think would be easier and look better. My dash onlu has one crack in it and its behind the defroster vents so its not to bad. But I wannaveither vinl wrap it ( get it done somewhere so it looks good) or this http://www.youngsfbody.com/inc/sdetail/1969/15478
Car: 91 Z-28 Convertible
Engine: 5.0L
Re: Another dash post
I just installed a cap on my 91 about a month ago. I got it on ebay for around $115. Only I know the difference. As long as you're not planning on taking your car to Barrett Jackson you will be fine. Just make sure you follow the install directions. Don't over glue. Mine looks great. It is the same color black and texture as the stock dash pad right out of the box. For $115 vs $385 for a new dash pad, I figured it was worth a try. My speaker vents caved in one morning when I was cleaning the dash so I needed a quick fix. I almost started to cry when I saw the proce of a new dash pad.
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
I put a cap on mine this winter,just follow the directions right and don't cover the screw holes that are in your defrosters.Like cvicha says!!!only you will know the difference.
Chuck84TA
Jul 15, 2016 09:05 PM
