1992 Camaro RS none of my gauges work someone help!!!
Old Jul 18, 2012 | 10:17 PM
Guest
Guest
Posts: n/a
None of my gauges work neither does my light. How do I fix this?
Old Jul 19, 2012 | 01:28 PM
ImBrandon's Avatar
Car: 1991 Pontiac Trans Am
Axle/Gears: 3:42
Re: 1992 Camaro RS none of my gauges work someone help!!!
check fuses. check your wiring harness see if everything is connected. check your ground wires. Use a multi meter on your wiring to see if you're getting power to your guages and lights. Make sure your battery is charged. check your headlight bulbs.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
justin57
Aug 20, 2015 07:05 PM
