Need complete center console 1988 camaro
Old Jul 29, 2012 | 09:25 PM
BigDrew11886's Avatar
I Need :
  1. console with 2 openings for windows and one for hatch, including radio bezel, upper and lower console without carpet preferably. if carpet black or grey.
  2. seats from 98-02 in very good condition
  3. prong electric module on hatch lid. ( my 3rd brake light isn't working and only one prong of the 4 is left. ) so i think that might be why. If you have any ideas please feel free to say them.
  4. passenger side fender with no rust or dents.
  5. aftermarket or iroc hood.
please pm or email me if you have any of the above. bigdrew11886@hotmail.com
Old Jul 29, 2012 | 11:13 PM
david86camaro's Avatar
Car: 1986 Camaro
Engine: 2.8
Re: Need complete center console 1988 camaro
For the 3rd brake light it may not be that, I have an '86 and the 3rd brake light is powered from the power through the shocks. It is different for different years so check that.
Old Jul 29, 2012 | 11:27 PM
Do you have air ride? I just have normal shocks. I can't find much information on this problem.
Old Jul 30, 2012 | 12:09 AM
Car: 1986 Camaro
Engine: 2.8
The shocks that hold up the rear hatch have power going though them, that is why they are so expensive. If the wire slips off the tab then the brake lite doesn't work (and the rear defrost would kick on (they share a ground).
Old Jul 30, 2012 | 01:51 PM
o wow. i had a slow moment. thanks i will have to check that out and let you know.
Old Aug 2, 2012 | 09:46 AM
I have found a center console. I looked at every wire connector and fuse even the shocks and still no third brake light. Next step is checking for power I just have to find an voltmeter.
Old Aug 2, 2012 | 10:51 PM
Car: 1986 Camaro
Engine: 2.8
One more thing I just thought of, if you have an '86 with the brake light on top of the glass there is one thing that I had to do to get mine to work. It was so many years ago that I had forgotten (I did this 18+ years ago and have not had to redo it yet). I had to wedge some rubber (I used part of an old bike inner tube) under the front edge (under the lens) because the electrical contacts under (and through) the glass are not making contact to the electrical "wire" on the surface of the glass.
Old Aug 3, 2012 | 10:06 AM
thanks! i have the low tail sport coupe though. still trying to figure it out......
Old Aug 4, 2012 | 11:41 AM
I traced all of the wires all the way to to ground. It ended up being the connection for the ground to the chassis on the passenger side. I also cleaned all the connections with brake cleaner and used steel wool on all metal connections. Thanks for your help.
1992 Trans Am
May 10, 2023 07:19 PM
Terrell351
Jun 13, 2021 01:13 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
Casey Meyers
Mar 2, 2016 10:46 AM
