Calling out ALL 3gs with 4th gen dash conversion
Old Aug 15, 2012 | 08:51 PM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Transmission: MN12 6speed
Axle/Gears: 3:42
after converting to the 4g dash. How many of you guys are running a/c and heater but think you have an issue with the amount of air being blown into the interior.
Old Aug 15, 2012 | 09:17 PM
sailtexas186548's Avatar
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
Re: Calling out ALL 3gs with 4th gen dash conversion
I
m not sure if you guys run the 3rd gen a/c box and fan, but if so I'll say the amount (volume) of air coming out of my 100% stock a/c system is not nearly enough. I want to try a higher CFM fan, or a cetrifical style one
Old Aug 15, 2012 | 09:23 PM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
Not much changes besides adding the 4th gen air ducts. Cut modify seal
Old Aug 21, 2012 | 02:14 AM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
found my 3g to 4g issue.
Old Aug 21, 2012 | 02:37 AM
haisud's Avatar
wow 4gen dash fit without cutting in 3gen?
Old Aug 23, 2012 | 05:05 PM
tf0r1's Avatar
Car: 92 RS 25th Aniv. V8
Engine: 350 L05 TBI
Transmission: 700R4 Raptor
wow!!!!
Any pics of how that dash looks? (please)
Old Sep 2, 2012 | 01:48 PM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
my original thread https://www.thirdgen.org/forums/inte...dash-swap.html from 2008
my new project.
should go well with my 4th gen door panels.
to stay on topic. for the 4g dash guys its best to fiberglass the 4th gen ducting onto the 3g hvac unit. ensures that you dont have leaks.
also the 4th gen ducting does not have the same flow pattern . theres some modifications that you have to sacrifice to get the proper amount of air flow into the interior
Vintageracer
Jan 10, 2020 05:33 PM
Casey Meyers
Mar 2, 2016 10:46 AM
cam-mike
Aug 24, 2015 07:23 AM
