fourth gen dash swap with ls1 swap questions
Old Sep 18, 2012 | 11:13 AM
4.8camaro's Avatar
Car: '89 Camaro
Engine: 4.8, ls9 cam, mpt76
Transmission: Built 4l60e, 3600 stall TC
I did a 4.8 swap to my 89 Camaro and then decided to do the dash swap. I got a dash out of a 99 v6 Camaro and installed it. I wired up the wiring directly from the cluster that had to do with lighting..etc directly to the third gen harness that I left behind the dash. I wired the data wires directly from the ECM.
My gauge cluster is so messed up now that I don't know what to do. The illumination works, which is good. But when I turn on the blinker, the indicator lights up and then when it cycles off, all the warning lights illuminate. Also, the speedometer, tach, oil pressure, and engine temp do not work. Do the gauges need to get a signal from the BCM or some box within the dash?
Someone help! This is so frustrating. I am debating on just getting aftermarket gauges to put in there.
Old Sep 18, 2012 | 08:56 PM
JacobIroc's Avatar
Car: 92 RS 25th Anniversary
Engine: 305 TBI -> 305 TPI
Transmission: T5/T56
Axle/Gears: 3.08 - 3.73+ soon
Re: fourth gen dash swap with ls1 swap questions
You need a v8 cluster. That will elliminate most of the problems.
Old Sep 18, 2012 | 09:05 PM
4.8camaro's Avatar
Car: '89 Camaro
I don't think that is even part of the issue I'm looking at
Old Sep 19, 2012 | 12:30 AM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
https://www.thirdgen.org/forums/inte...dash-swap.html
Read that thread, see if it helps you out any
Frozer!!!
Jan 19, 2024 04:55 PM
Casey Meyers
Mar 2, 2016 10:46 AM
InfinityShade
Aug 22, 2015 08:00 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
