Firebird Gauges in a Camaro
Old Sep 27, 2012 | 12:18 AM
383 Power's Avatar
Car: 1982 SC/1984 Z28
Engine: 305 4BBL/305 4BBL H.O.
Transmission: 700R4/700R4
Axle/Gears: 4th Gen 3.23 Posi/3.73 10 Bolt
Can I put Firebird gauges in a camaro without any fuss or muss? In otherwords, do they bolt right in and connect the same?
Old Sep 27, 2012 | 01:24 AM
toomany's Avatar
Re: Firebird Gauges in a Camaro
They would probably plug into the dash harness and read correctly (provided same year, motor type, gauges or idiot lights). But to actually bolt them in would require a dash swap.
Old Sep 27, 2012 | 09:50 AM
nosajwols's Avatar
Car: 82 Z28
Transmission: TH350 for now
You will likely need to swap the dash because the clusters are two totally different sizes. Also in many years the Camaro had a mechanical speedo where the Firebirds were electric.
In short answer is it is not a direct swap.
Old Sep 28, 2012 | 12:40 AM
383 Power's Avatar
Well, It was a thought. Thanks for the quick reply guys.
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
rocn7roc
Sep 21, 2021 02:16 PM
colton_carlson
Mar 8, 2019 12:21 PM
justin57
Aug 20, 2015 07:05 PM
