steering wheel Problem :(
Old Oct 6, 2012 | 02:56 PM
Lmancha96's Avatar
Car: 1992 Camaro (Z28 Clone)
Engine: LB9|TPI
When I purchased my car It came with a hideous aftermarket steering wheel.
After having the car for about a month I decided to buy the original steering wheel for it.
I had no problem taking off the aftermarket steering wheel (just a couple bolts) but when I attempted to place the original steering wheel on it, It wouldnt go on because there is a round metal piece in the way. I tried to remove it but couldnt find a way to do so.
Can anyone
Old Oct 6, 2012 | 03:34 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: steering wheel Problem :(
Probably the adapter for the aftermarket wheel.If so, gonna need a steering wheel puller to get it off.Then you'll need the stock hub for the stock wheel.
Old Oct 6, 2012 | 04:03 PM
Lmancha96's Avatar
Engine: LB9|TPI
Thanks dude,
Ill see what I can do when i get off from work.
Would you happen to know where I can get one of those Hub adaptors?
Thanks again.
Old Oct 6, 2012 | 08:36 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
Pep Boys, almost any parts store, Ebay. To put the stock wheel on you'll need the hub, not sure where to get those maybe a junkyard.
Old Oct 7, 2012 | 02:27 AM
Spaceboy1980's Avatar
Car: 1990 Camaro RS
Engine: L31
The stock wheel just slips on the splined shaft that will be there after you take off the adapter for the aftermarket wheel. There is no hub to replace. Slip on wheel, tighten down nut, install lock ring, replace horn pad and you're done. Airbag wheels are a little different but not much.
BlueIroc-Z
Jun 9, 2019 03:22 AM
backtothe80s
Sep 5, 2015 12:39 AM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
mustangman65_79
Aug 9, 2015 03:00 AM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
