Seat foam
Old Oct 8, 2012 | 01:42 AM
Eightyninef's Avatar
Seat foam
Is there a way to rebuild seat foam? My seat covers are mint, but the shape of the seat has changed over the years.
Old Oct 8, 2012 | 10:12 AM
Ruckusz28's Avatar
Car: 1986 IROC-Z
Axle/Gears: 4:10
Re: Seat foam
In the past I've used great stuff to fill in some holes and all that. Once it dries you can shape it with a razor.
Old Oct 8, 2012 | 04:07 PM
DJ_91RS's Avatar
Car: 91 RS, 89 IROC
Engine: 305 TBI, still deciding
Transmission: 700R-4, still deciding
Axle/Gears: stock, 3:73 IROC
Re: Seat foam
http://www.hawksthirdgenparts.com/se...find=seat+foam
Old Oct 8, 2012 | 04:49 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
Re: Seat foam
what is great stuff?
Old Oct 9, 2012 | 12:30 AM
Spaceboy1980's Avatar
Car: 1990 Camaro RS
Engine: L31
Re: Seat foam
Great stuff is expanding foam and would not work in a seat. It cures hard and once crushed, stays crushed. You might as well repair the padding with a chunk of wood if you were to go that route.
Old Oct 9, 2012 | 07:51 AM
thecovergirl's Avatar
Car: 89 Firebird
Re: Seat foam
You can use 1/2 inch thick foam if your seats aren't too bad and after you glue it where you want it, you just shave it down to the shape of the seat. If your seats require thicker foam, you can do the same thing as well.
Old Oct 9, 2012 | 11:15 AM
Jimmy64D's Avatar
Car: 89 Iroc
Engine: 5.7 TPI
Axle/Gears: 2.77
Re: Seat foam
Wonder if a combo of high density foam and then some memory foam on top would work?
Old Oct 9, 2012 | 02:16 PM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Re: Seat foam
couldnt get the hawks link to work do they do the foam for GTA seats as well?
Old Oct 9, 2012 | 04:03 PM
Car: 89 Firebird
Re: Seat foam
It would work as long as the high density is not too hard because you don't want the firmest foam there is. You need some give to it.
Old Oct 9, 2012 | 04:04 PM
Car: 89 Firebird
Re: Seat foam
As far as I know, they only carry the Camaro foam cushions. I have not found anybody that sells the GTA foam.
MrPackstin
Oct 25, 2017 08:09 PM
GageBrand
Oct 22, 2015 02:30 PM
Briandrex
Oct 5, 2015 06:20 AM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
kitt23
Sep 26, 2015 07:48 PM
