Power Door Locks not working
Old Oct 15, 2012 | 08:55 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
They power door locks in my car dont work. It sounds like they are working when you hit the lock buttons, but they don't actually lock or unlock. Are the motors weak or is something else faulty?
Old Oct 15, 2012 | 09:04 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: Power Door Locks not working
1. Get into the door and clean and lube EVERYTHING.
2. Remove the driver's side kick panel and make sure that the screw holding the relay box to the body is tight. The relay grounds through that screw, so if it's loose, no locks...
Old Oct 15, 2012 | 10:05 PM
akanitro's Avatar
Car: 1989 GTA, 2004 Z06, 2008 Expedition
Engine: L98, LS3, 5.4L
Transmission: 700R4, MN6, Auto
Axle/Gears: 3.23, 3.42, ?
Door lock actuators are a common issue also. If they don't work out perfect after lubricating all the linkage, just replace the actuators. You can buy them aftermarket cheap.
Old Oct 16, 2012 | 10:06 AM
1Aauto's Avatar
Former Sponsor
We carry new door lock actuators for you car. Here's a link to them if you would like to see what we have. http://www.1aauto.com/1A/DoorLockAct...ampaign=1ATony
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
