digital dash problem
Old Nov 20, 2012 | 05:57 PM
GTAman's Avatar
Car: 1988 Trans am GTA
Engine: corvette 350 swap
Transmission: t-5 swap
Axle/Gears: 3.27:1 borg warner 9-bolt w/ PBRs
check out the video. it's like it's illuminating the whole pattern. what's most weird is that it illuminates the up shift indicator...and the car is originally a automatic!
anyone ever encounter this?
Old Nov 24, 2012 | 11:47 PM
Jetmeck's Avatar
Car: '89 GTA 9,000 MILES
Axle/Gears: 3.27 9 bolt
Re: digital dash problem
Likely a loose connection.....when cold everyhting contracts and when its warm it will expand and make a better connection.
Old Nov 25, 2012 | 06:07 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
My guess is that you have a short across the pins because the pattern seems to repeat exactly every time. When you hit 1000 RPM, several bars up to 3400 RPM and the shift indicator light up. I would take the cluster out and take it apart to see what's going on in there. The actual glass screen is connected to it's printed board by pins. Once you get all the bezels out of the way, you can remove the screen by slowly, carefully pulling it straight out (forward). If you don't find any obvious signs of a short, you will probably need a new tach board, which will likely mean a complete used cluster.
Old Nov 29, 2012 | 12:25 AM
GTAman's Avatar
Thanks! when i get brave i'll dig into it.
The_Phoenix
Feb 4, 2016 07:10 AM
Pilotrick50
Sep 2, 2015 12:48 PM
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
Sanjay
Aug 12, 2015 03:41 PM
beachrodder
Aug 7, 2015 04:27 PM
