HVAC Selector problem in '87 TA with digital dash
Old Dec 6, 2012 | 03:36 AM
83 Crossfire TA's Avatar
I have air only coming out of the defroster... yea, I know, a vacuum leak causing the vacuum selector not to work, the default... yada yada....
Nope. Yes, my '83 TA, my 87 Formula 350, yes, your camaro... all have that funky vacuum switch. Not my '87 TA with a digital dash:
2 electrical connectors, no vacuum lines.
Anyone have any idea where to look?
Attached Thumbnails HVAC Selector problem in '87 TA with digital dash-photo.jpg
Old Dec 6, 2012 | 12:35 PM
82tarecaro's Avatar
Re: HVAC Selector problem in '87 TA with digital dash
Are the HVAC doors vacuum controlled or do they have electric motors on them? Just wondering if it still could be a vacuum problem but you need to look elsewhere for the leak
Old Dec 6, 2012 | 01:46 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
https://www.thirdgen.org/forums/pict...822766&thumb=1
I found this in my shop manual for the Digital Dashes.
Old Dec 12, 2012 | 03:17 AM
thanks, but that drawing can't be of the correct setup. Like you see in the picture that I posted, there are no vacuum lines going to the back of the controller like that drawing shows, and it shows a selector that uses a slider, where mine doesn't have that, but has push-buttons.
Old Dec 12, 2012 | 04:31 AM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Yours is still vacuum controlled, there's a vaccum servo in there somewhere, prob right there. Follow the vacuum lines from the ac heater box back and see where they go. I'll look in my fsm and see if it helps.
Old Dec 12, 2012 | 08:07 PM
stealtht/a's Avatar
Oops, I think I might be wrong about that, still not sure after checking out my 87 Factory service manual. The actual 87fsm doesn't mention the digital dash option at all, but the 87 electrical supplement describes the digital dash, but not the push button hvac. However, there is a diagram in the 87 fsm that doesn't seem to have a reference and isn't in my 86 fsm (sorry, don't have a 88). I think it shows the ELECTRIC actuators for the temp control that go with the push button hvac. There's probably electric actuators for the modes, too, but I don't seem to have that supplement.hth
Attached Thumbnails HVAC Selector problem in '87 TA with digital dash-image.jpg
The_Phoenix
Feb 4, 2016 07:10 AM
Pilotrick50
Sep 2, 2015 12:48 PM
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
Sanjay
Aug 12, 2015 03:41 PM
beachrodder
Aug 7, 2015 04:27 PM
