driver seat stuck
Old Dec 17, 2012 | 10:23 PM
transam3504bbl's Avatar
Car: 1988 trans am
Engine: 350 4bbl
driver seat stuck
Hello..... I'm tearing down my interior to change my carpet and I can't advance or back up my seats tried using penetrating lube on the tracks..... tried playing with the mechanism.... but still no luck any advice??
Old Dec 17, 2012 | 10:58 PM
Formula_383's Avatar
Car: 1989 Formula 350
Re: driver seat stuck
Track could be bent, have seen that before. Or something could be caught in it not letting it slide.
Old Dec 17, 2012 | 11:05 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Unbolt the seat and turn it upside down to see where the problem is.
Old Dec 18, 2012 | 12:52 PM
Car: 1988 trans am
Engine: 350 4bbl
I tried to get it out but the 2 rear bolts that hold the seat down are un accessible because the seat is all the way back any tricks
Old Dec 18, 2012 | 03:47 PM
kentuckyKITT's Avatar
Car: 2 T-Tops
Engine: 327/305
Transmission: TH350/700R4
Axle/Gears: 3:42/2:73
Funny story. I once bought a 3rd gen that had a stuck driver's seat and after finally getting the seat out, found a cigarette lighter that was mangled in the track.haha Look for that! Seriously, though, if the seat is all the way back and you have small enough arms, you can reach under the seat from the front and feel your way back to the rear nuts with a wrench. You'll only be able to turn it a milimeter at a time and it will drive you nuts, but that's how I got one out. Also, you can unbolt the seat from the track at the front, so that you can lift it up more out of your way. You should be able to reach those bolts in the bottom of the seat if it's all the way back.
Old Dec 19, 2012 | 11:13 AM
Car: 1988 trans am
Engine: 350 4bbl
Will try that tonight Thanks very much ill let you know how it goes
1992 Trans Am
May 10, 2023 07:19 PM
zayne0
Aug 24, 2015 07:22 PM
TRANSAM82-92
Interior Parts Wanted
Aug 15, 2015 01:26 PM
Mister_Johnny99
Aug 14, 2015 12:59 PM
scottmoyer
Aug 9, 2015 10:18 PM
